would the pt cruiser turbo that air sierra used for his 2.4l fit on the 2.5l? - Page 2 - JeepForum.com
post #16 of 50 Old 11-17-2008, 11:18 PM
KKiowaTJ
Originally Posted by hotrod_hooligan View Post
It's too late for me to even touch this, wrong on so many different points.
Lets hear it because my old YJ had a turbo on it? I wanna know what you think will work?
MOPAR!
KKiowaTJ is offline
post #17 of 50 Old 11-17-2008, 11:56 PM
subaruboy
Originally Posted by David Hinton View Post
would the turbo from a pt cruiser or srt4 work for the 2.5l? or is there another compatable turbo for the 2.5l that is pretty cheap?
thanks
i can see your thread is getting hyjacked rather quickly, so i'll try to keep it realtively short. the short answer is, the turbo hardware from the pt cruiser will not work with your enginer.
supplying the shop with the turbo from a PT cuiser and telling them to have at it is pointless. the 2.5L and 2.4L being completely different engines, there is nothing compatible about the pt cuiser setup and your current engine. it would be more cost effective to buy one of the few turbo kits available for the 2.5L. usually you can also buy a computer programmed from the company that sells the kits to install on your jeep that will tune it for the turbo. without the modified tuning, the turbo kit on your engine is pretty useless. the 2.5L doesn't have forged internals, and the compression ratio is quite a bit higher than is typically run on a forced induction motor, so getting the motor to run reliably without blowing up will require low boost and fine tuning.
alternatively, you could sell your jeep and get one that has a 2.4L in it. if you do that, then you can get the turbo from the pt cruiser and the intake and exhaust manifolds will bolt right up to your jeep. again, it lacks the reinforced internals and low compression ratio, so there is some tinkering involved, but there is a very good thread in here about a guy already doing the project with good results.
00 Jeep TJ SE Amberfire Pearl- Sold :'(
87 Yota Pickup
05 PBM M6 GTO
07 Ford Focus
subaruboy is offline
post #18 of 50 Old 11-17-2008, 11:57 PM
subaruboy
just curious, what year was your YJ? Did you install the turbo on it yourself, or did you buy it like that? And are you sure that you didn't have any sort of computer modifications at all?
87 Yota Pickup
05 PBM M6 GTO
07 Ford Focus
post #19 of 50 Old 11-18-2008, 01:06 AM
KKiowaTJ
Late model 95 with the OBD-II computer. Borg Wagner turbo, Jet stage 2 chip, Adjustable map sensor, High volume fuel pump with adjustable fuel pressure regular. Doug Thorley custom fit header, Dont remember the intake mani-fold, with parts from here and there to complete it, Waste gate, Blow off, Lines etc. But for the money, A 350 TBI would have been much better. A stock 350 puts out more stock HP/TQ than a 4cyl turbo in a jeep. I never had mine on the dyno, But i would have to say with all the mod's, Ballpark maybe 50%. I didn't do all the work myself, But i know that other than the chip, The PCM was left stock.
MOPAR!
KKiowaTJ is offline
post #20 of 50 Old 11-18-2008, 07:23 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Other than the first line you posted, Do you have any clue what you are even talking about? All your doing is pumping up your post count. If you run 02 Sim's, Hows the engine going to know what temp, Air to add, and fuel. The computer is fine, Might need a chip, But thats all. The only thing you have right is that you will need new manifold's, Intake and exhaust that is larger to handle a boost of a turbo. Plus an inter-cooler larger exhaust.
Yes I have a pretty damn good idea of what I'm talking about. Been researching how to turbo & supercharge a 4.0L for about 3 yrs now. The OP has a 2.5L, which isn't much different. I've ridding in a custom turbo Rubicon, WITH O2 SIMULATORS.
Why O2 simulators? So you can dyno tune the engine, and program custom timing and fuel maps. The computer won't 'adjust' for closed loop vs open loop because it won't know how much O2 is leaving the engine - you tell it by configuring it on a dyno.
How is the computer going to magically adjust for the increased air? How is the fuel pump going to deliver the increased fuel necessary? Can the stock pump even keep up? How do you know? Have you dyno tuned a turbo 2.5L? Have you flow tested the 2.5L pump?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #21 of 50 Old 11-18-2008, 10:03 AM
breckboarder55
There is so much mis-information in this thread its not even funny. It won't fit, I've never heard of a 02 simulator. The only thing I can think of for this is that the stock computer is pulled for a standalone, because if you don't have a 02 sensor with the stock computer it will just throw a code. Now as far as a "simulator", maybe another 02 sensor hooked up to a wide band to properly tune the air/fuels.
A map sensor adjuster... A joke in the tuning world, these are basically the little boxes you see on ebay and the back of magazines that claim 10 hp gains for 20 bucks... Its basically a regulator that you wire into your map sensor and turn a screw to trick your computer into thinking its hotter or colder than it really is... Flaw though, its not accurate enough to make up for any significant changes on a N/A car, and OBD over time will re-adjust to what it thinks it is supposed to be. It also vary time to time with what the real temperature is. How do I know? A good friend and I once used one on his SRT-4, before he realized it was a bad idea. After that he ran a proper piggy back, to go with his 50-trim turbo.
I've built a 50 trim turbo SRT-4, done some work on a friends T-88 Supra, personally built my own T-70 powered RX-7, and am starting to help a buddy with a T-25 powered miata. Real world experience...
Subarukid is pretty on with what he is talking about, it might be possible to run with the stock injectors and pump... However, you never want to run them past their efficiency at 85%. Oh, and by borg wagner turbos I hope you meant Borg Warner....
This is for the OP... It would be cheaper, and more reliable in the long run for you to do a 4.0 swap or V-8 swap. If you are set on it, it is possible, but it is less tested. Shop work and fabricating can get pretty expensive. You could always look into selling your 2.5 for a 4.0.
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #22 of 50 Old 11-18-2008, 06:40 PM
vector6
google...
http://www.titanmotorsports.com/pe02si.html
vector6 is offline
post #23 of 50 Old 11-18-2008, 10:06 PM
KKiowaTJ
If you read the other post than you would know that i had one, waste of money. Stock PCM will work with a chip, Yes i could have gotten more out of it but why? Its still a 4cyl jeep, You dont have to tell me what works or not on a 2.5 turbo kit, Drove mine 15k problem free, And then sold it. never needed to "dyno tune' mine is as it wasnt meant to run the 1/4 mile.
MOPAR!
KKiowaTJ is offline
post #24 of 50 Old 11-18-2008, 10:36 PM
-Rudy-
2003 WJ
I think everyone is pretty much partially wrong to being flat out stupid.
-On an NA Fuel-Injected motor, you will need some sort of engine management to tune the damn thing (no, a chip will not do it.) Who knows what kinda hell you put your poor motor through running it like that.
-You don't need an intercooler or anything special... that all comes with power-levels and your set-up.
-For someone with "real world experience" how the hell do you not know about o2 sims? They're a pretty common tool when you start gutting/eliminating cats on OBD I & II vehicles.
All in all. No, it won't just bolt up. But, yes it can be done. But, no it probably wouldn't be cost effective. But, yes it would be unique. But, no I wouldn't waste my time.
And there you have my opinion. And now on to your basic parts list:
-Turbo (Whatever size for your application, in this case probably a rather meager unit.)
-Custom exhaust manifold or adapter.
-Custom exhaust piping to at least the stock catalytic converter (after that, it's up to you.)
-Custom intake setup.
-Wastegate, oil lines, etc. etc.
-Upgraded fuel pump and injectors.
-Some way to control the AFR. (Piggyback, standalone, etc.)
I'm sure I might have missed some things.
2003 WJ Laredo 4.0/242: 3" IRO, Bilstein 5125, Supporting Mods
2004 WJ Limited 4.7/247/QD
-Rudy- is offline
post #25 of 50 Old 11-18-2008, 10:46 PM
sailsurf7713
Did the OP ever come back?.
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
post #26 of 50 Old 11-18-2008, 11:31 PM
breckboarder55
Supra... runs an AEM standalone
RX-7... pre-OBD II and runs a standalone
SRT-4, never ran one. Never had a problem...
01 Honda S2000DD
post #27 of 50 Old 11-19-2008, 08:09 PM
-Rudy-
2003 WJ
How the hell you managed to tune 2 stand-alones and not know what o2 sensors/simulators do, is beyond me. They're rather basic tricks, like I said.
SRT-4 has pretty much a straight pipe for a stock exhaust, therefore I don't believe it'd throw codes.
-Rudy- is offline
post #28 of 50 Old 11-19-2008, 08:36 PM
'B'wigstrailrig
Could he just pull motor and all from the PT cruiser? Then he would have the forged inners, exaust manifold and all that mumbo jumbo. I dont have a clue what Im talking about but does that make sense to someone that does? Could he use the computer from the PT cruiser as well?
'B'wigstrailrig is offline
post #29 of 50 Old 11-19-2008, 08:39 PM
-Rudy-
2003 WJ
I wouldn't really know how to answer that question. With the 2.4L models, I'm sure you could interchange most of the parts, however I believe that in a jeep, the motor is mounted traverse and in the PT it is mounted horizontally. Again, I'm not 100% sure.
-Rudy- is offline
post #30 of 50 Old 11-19-2008, 08:46 PM
'B'wigstrailrig
Yeah its probably horizontal but if its the same 2.4 as a jeeps then I would think it would mount straight. Maybe need a different bell housing. Again I dont know. Were the hell is the OP? Are you pulling this from a junk yard or robbing your mother in law? Maybe you should get the whole motor while your at it.
Sierra Expeditions IPF H4 lenses Jake03TJ TJ Wrangler Technical Forum 5 01-13-2010 03:00 PM
YUKON v.s. SIERRA GEARS Tim TJ Wrangler Technical Forum 9 05-28-2009 09:52 PM
Olympic Sierra Rack takthekak TJ Wrangler Technical Forum 4 07-12-2006 06:32 PM
sierra rack limecolbyjack TJ Wrangler Technical Forum 4 07-05-2005 09:55 AM
Anyone Have a Sierra Hardtop and 1/2 Doors? kdavis TJ Wrangler Technical Forum 4 07-21-2003 06:18 PM
