Work-around for broken ignition, but should I replace steering column still? - JeepForum.com
post #1 of 7 Old 09-26-2010, 05:27 PM Thread Starter
BigFatDummyHead
98 TJ was stolen/recovered. Eventually the steering column ignition switch pin broke. Rather than replace entire steering column, I rigged a work-around switch and all is good.
My concern: Is there any way that the broken ignition part might cause steering problems later down the road?
BigFatDummyHead is offline
post #2 of 7 Old 09-26-2010, 07:46 PM
heymatt
That piece can be replaced without buying a new column. Try D A V E Y S J E E P S . C O M - Specializing in Jeeps & Jeep Parts they have the part. Some one else posted that Cherokees use the same piece, I can't confirm that it's true.
heymatt is offline
post #3 of 7 Old 09-26-2010, 07:56 PM Thread Starter
BigFatDummyHead
I got the ignition working well without replacing the part (bypassed with a switch), just wondering if the piece that broke is an essential part of the steering column. I don't care about the ignition anymore, but don't want my steering ruined if I leave that part unfixed.
post #4 of 7 Old 09-26-2010, 09:40 PM
poormatt
It shouldn't bother anything steering-wise, but it's nice to have anyway. I got mine from the junkyard for 15 dollars. I will confirm for a previous poster Cherokees are adequate donors. Any TJ 97-06 shoudl work as well.
poormatt is offline
post #5 of 7 Old 09-27-2010, 10:38 PM Thread Starter
BigFatDummyHead
Thanks for the input, Matts. Piece of mind is had. -Mike
post #6 of 7 Old 09-28-2010, 01:25 PM
TimmiT
OP, is there anyway I could get a rundown on how you bypassed the ignition pin? I have the same problem with mine, and I don't feel like getting a whole new steering column.
I don't think it should cause any problems with the steering down the road, since the only broken piece goes directly into the Ignition switch.
TimmiT is offline
post #7 of 7 Old 10-04-2010, 09:38 AM
stormtj
Op any info on how you did this?
stormtj is offline
ignition , ignition pin , steering , steering column , switch
Ignition failure requires new steering column? jeep-rambler TJ Wrangler Technical Forum 34 06-27-2013 11:38 AM
broke steering column ignition pin redsled1217 TJ Wrangler Technical Forum 4 10-22-2009 02:36 PM
Ignition Problem - How hard to replace steering column? stereoman405 TJ Wrangler Technical Forum 0 03-31-2008 04:16 PM
Replace steering column tdewit YJ Wrangler Technical Forum 7 10-02-2006 03:29 PM
Steering column ignition switch question Charlie L YJ Wrangler Technical Forum 0 03-22-2002 05:56 PM
