Quantcast Woohoo! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Woohoo!
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 05-27-2007, 09:35 AM   #1
VaLoRiaN
Woohoo!
I just wanted to share my joy with everyone on what I found while installing my lift yesterday. After researching Jeeps for a few months I knew that everything but a Rubicon came with a D30 Front and D35/D44 Rear so I didn't really pay attention to the front axle. When I crawled up under it last night, though, I discovered that there had been a D44 Installed on the front as well! I'm no expert but when you turn the wheels pretty stiff it makes a big loud repeating clicking sound which I have read is the lockers that do that? If so that would be awesome. But that's all for now.
[COLOR="Black"][B][CENTER][FONT="Arial Black"][SIZE="3"]2003 Jeep Wrangler Sahara[/SIZE][/FONT][/CENTER][/B][/COLOR] [CENTER][COLOR="Wheat"][B][FONT="Arial"][SIZE="2"] Khaki [/SIZE][/FONT][/B][/COLOR] with [B][FONT="Arial Black"][SIZE="2"][COLOR="Sienna"]Brown Soft-Top[/COLOR][/SIZE][/FONT][/B][/CENTER]
[B][FONT="Arial Black"][SIZE="1"]4.0L I-6, 5 Speed, D30/D44 with 3.73 Gears, 33x12.50x15 BFG All-Terrains on Canyons, ARB Bull Bar with Warn x9000i Winch & Fog Lights, T-Case, Oil Pan, and Gas Tank Skids, Fully 7-Speaker Upgraded Sound System with Amp & Clarion 6 CD Changer and Rock Shifter Knob :), Soon to Come: ARB Rear Tire Carrier, Shrockworks Rocker Guards, Pioneer DVD/CD Receiver, 2.25" Suspension Lift, 1" PA BL, 1" JKS BMML, 1.25" Spidertrax Wheel Spacers, and MORE! [/SIZE][/FONT][/B]
VaLoRiaN is offline   Reply With Quote
Old 05-27-2007, 09:37 AM   #2
Rocky529
Jeep
Rocky529's Avatar
Looks like a Dana 44 but you indeed have a Dana 30 front without any sort of locker (assuming your Jeep is stock).
Only Rubicons have 44 fronts.
The clicking sound may be your power steering pump.. any leaks?
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 05-27-2007, 09:46 AM   #3
pvjeeper
yeah i was going to say that the power steering is telling you thats all the farther you can go. Mine does that to does it want to die?
pvjeeper is offline   Reply With Quote
Old 05-27-2007, 09:54 AM   #4
Stu Olson
Stu Olson's Avatar
Well, I'm no expert either, but assuming you mean you are rotating the wheels and not turning the steering wheel back and forth, I would venture to say you have a lunch box locker in your front diff.....perhaps a lockrite or a similar model.
Edit: Or....that clicking is your u-joints and you are really in trouble.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Old 05-27-2007, 10:04 AM   #5
VaLoRiaN
No, my last Jeep did the exact same thing there's no problem with the steering or anything like that and no it doesn't try to die on me at all that's why I thought maybe it was a positive thing. As for the axle it was upgraded not stock. It's the exact same as the rear and even has the metal wingnut that everyone said to look for so it's a 44 unless the D30 and D44 are twins.
Old 05-27-2007, 10:05 AM   #6
Rocky529
Jeep
Rocky529's Avatar
The front Dana 30 has a metal, threaded fill plug on all TJs.
Don't be too upset, there is nothing wrong with a Dana 30 front.. the rear is what you should be concerned about.
Old 05-27-2007, 10:07 AM   #7
VaLoRiaN
Is it the same shape as the 44 as well? Because when I say they're identical I mean they look exactly the same.......
Old 05-27-2007, 10:07 AM   #8
Rocky529
Jeep
Rocky529's Avatar
Yes....
Old 05-27-2007, 01:11 PM   #9
jack9580
post up a pic of the front diff so we can see
2004 WJ Freedom Edition w/4.7 H.O. heavily modded (sunk + totaled R.I.P. 9/06)
1998 TJ Sahara lifted, locked, and tons of crap bolted on (Sold)
1993 ZJ limited 5.2 (spare beater)
2004 WJ limited w/4.7 H.O. Addco rear bar, JK Rubi wheels
jack9580 is offline   Reply With Quote
Old 05-27-2007, 01:38 PM   #10
jeeptillidie
Compare the size of the 2 not the shape. The shape is not exact but is very similar between the two. The dana 30 has a visibly much smaller pumpkin than the 44. Its not hard to tell.
jeeptillidie is offline   Reply With Quote
Old 05-27-2007, 01:43 PM   #11
TJ on the Rocks
No , the 30 and 44 covers are not shaped similarly . See this for a comparison . Or here
[SIZE="7"][SIZE="7"][SIZE="5"][URL="http://www.atozfabrication.com/catalog/"][B][CENTER][SIZE="5"][COLOR="Red"]AtoZ F[/COLOR][COLOR="White"]abric[/COLOR][COLOR="Blue"]ation
[/COLOR][/SIZE][/CENTER]
[CENTER][B][/SIZE]
[SIZE="4"][/URL][/B][COLOR="Red"][/SIZE][/SIZE][SIZE="3"][URL="http://www.stickylee.com/catalog/index.php"]www.stickylee.com[/URL][/COLOR][/SIZE][/B][/CENTER][/SIZE]
TJ on the Rocks is offline   Reply With Quote
Old 05-27-2007, 08:15 PM   #12
VaLoRiaN
Looking at the 2nd link you posted (which was extremely helpful) yes they are sort of similar but the two I have on mine are IDENTICAL and I know the rear doesn't have a D30 on it. It would be fairly obvious looking at that link and I would pretty much guarantee it that the previous owned has upgraded from the stock D30 to a D44 which is extremely great because that is gonna be huge when it's not my DD anymore and I just use it for off-roading. I'll go look again to be sure though and I don't have a digital camera or I'd post up some pics. Thanks Guys!
Old 05-27-2007, 10:55 PM   #13
CCrew
Sure sounds like a good chance it's a 44 with a lunchbox locker to me. At least with the amount of info we're working with.
-Roger
CCrew is offline   Reply With Quote
Old 05-27-2007, 11:09 PM   #14
charlescho
got a pic of it ?
[SIZE="3"][FONT="Impact"][COLOR="Cyan"]ABC - A/Ox4 - SAMPLE - OPQRST[/COLOR][/FONT][/SIZE]
charlescho is offline   Reply With Quote
Old 05-28-2007, 12:55 AM   #15
bigchevyman24
You have to ask yourself why would the p/o put a 44 in the front when a 30 does a great job up to 37's??? Why put all the money into that unless you find a locked 44 for basically free?(Just have to pay the cost of the install) Just a thought....
2000 WJ - I6, Auto, 2WD 2" BB, 18" JK wheels/32" tires, Converting to 4wd
---2WD TO 4WD CONVERSION---
97 TJ 4" lift, 35" boggers, lockright front D30, 9k winch - SOLD
95 XJ 33" TSL's, 2" BB, SEVERE trimming - SOLD
2003 WJ LIMITED PART OUT!!!!!!!!!
bigchevyman24 is offline   Reply With Quote
  • WOOHOO! New JK! - JK Wrangler Technical Forum (2 replies)
  • Woohoo - YJ Wrangler Technical Forum (13 replies)
  • WooHoo! - TJ Wrangler Technical Forum (0 replies)
  • WooHoo - YJ Wrangler Technical Forum (1 replies)
  • 22 MPG Woohoo!!! - TJ Wrangler Technical Forum (15 replies)
Glock Forum
