Wont Start, Strong smell of gas - JeepForum.com
post #1 of 15 Old 12-20-2008, 02:47 PM Thread Starter
AlTheKillerr
AlTheKillerr's Avatar
I tried the search but it kept coming up as a blank page so please help out. I just used my jeep ~2 hours ago and it was running fine. i moved her up the drive and onto the road so my dad could get out. now i went to move it back down so i can pack my stuff into it and it wouldnt start. at first it just clicked. then i tried again and it sounded like it was wanting to turn over. like the sound it makes the split second before it wants to turn over? but it wont. also i thought i smelled an egg smell but smelled around and it smells like gas. i see no leaks anywhere and i could see just alittle exhaust coming out and thats where the gas smelled seemed to be coming from. any idea whats going on with my jeep? its got me puzzled
Photographer
AlTheKillerr is offline
post #2 of 15 Old 12-20-2008, 02:57 PM Thread Starter
AlTheKillerr
ok so i got her to start by giving her a little gas but as soon as i let off she wont idle so she wants to die. still smells like its running rich or something. same smell as my 69 jaguar e-type (has an inline 6 4.2l)
Photographer
post #3 of 15 Old 12-20-2008, 04:30 PM Thread Starter
AlTheKillerr
well she started and is running but still im a little worried about it
anyone
Photographer
post #4 of 15 Old 12-20-2008, 05:11 PM
Brandon97TJ
So you started it and it was running and when you were letting it idle it just died? Your jeep might not be running a good a/f mixture...how old is your upstream o2 sensor?
2000 TJ Sport
Brandon97TJ is offline
post #5 of 15 Old 12-20-2008, 05:16 PM Thread Starter
AlTheKillerr
the up stream is probably from factory so 99
shell run now no problem but still smells a bit rich to me and i do have to drive it tonight from her to the step moms place (~20 minute drive at ~65mph) is it ok that i drive it just this one time?
Photographer
post #6 of 15 Old 12-20-2008, 05:25 PM
Brandon97TJ
Yeah its fine but if it starts to "stutter", you might want to replace that o2 sensor. Especially if you smell gas, that means the o2 is giving bad readings and is killing your MPG. On average I get 20mpg but when my o2 went bad I was getting around 9....yeah. If it's not a big issue you can get one for like $35 shipped at rockauto.com or you can get pretty much the same one from Autozone or similar for $55.
I would make sure that you're running rich first before buying anything though. Sometimes a lazy o2 won't trigger a CEL too so keep that in mind.
2000 TJ Sport
post #7 of 15 Old 12-20-2008, 05:32 PM Thread Starter
AlTheKillerr
awesome thank you for the help. my buddy is coming over to take a look at it too. hes a tech at the jeep dealer so i can see what he can get me (price wise) for a new sensor if thats what it is
Photographer
post #8 of 15 Old 12-20-2008, 05:40 PM
Brandon97TJ
My dad took my jeep to the dealer one time and it was like $75 per sensor. Crazy price, but since he works there he could probably get it wholesale. good luck! let me know what fixes your problem
2000 TJ Sport
post #9 of 15 Old 12-20-2008, 06:10 PM
flexsaharatj
let me know what you find out... the same thing has been happening to me... the car would completely die, I then go under the hood, play around with the cables that go to the battery and get power back, the car would start and then stutter and die... I would have to give it gas and let it run for a while before it's fine... no problems then but a strong smell of gas does exist...
I'm going to tighten my battery cables and see what else I can do
flexsaharatj is offline
post #10 of 15 Old 12-20-2008, 07:53 PM
Brandon97TJ
Clean your throttle body too...might be some gunk up in there....theres tons of posts on here about that
2000 TJ Sport
post #11 of 15 Old 12-21-2008, 10:38 AM Thread Starter
AlTheKillerr
well we decided to get a new battery just to start to eliminate things and it started right up. so im going to go back out and see if she starts no problem this morning after its been sitting all night. im guessing the gas smell was unburned fuel making its way out the exhaust or something. it didnt have that smell after we got the new battery in and it ran for a minute
Edit: started no problem and there was zero smell. the battery that we got to replace the old one was alot bigger for some reason. we triple checked the booklet and with the guys at the place and everything said this was the right battery. maybe my brother put in the wrong one years ago but this one has 750 CCA where as the old one had something like 530 CCA
Photographer
post #12 of 15 Old 12-21-2008, 10:43 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If the engine cranks/turns over normally and at the same rpms but just doesn't start, it's not the battery.
Jerry Bransford is online now
post #13 of 15 Old 12-21-2008, 02:18 PM Thread Starter
AlTheKillerr
what should i look at then? its been running fine since the new battery
Photographer
post #14 of 15 Old 12-21-2008, 02:24 PM
Jerry Bransford
Administrator
Sorry, I thought the starter was cranking the engine normally/ok but the engine just wasn't starting. I just now figured out you meant it was just really only barely clicking.
post #15 of 15 Old 12-21-2008, 03:04 PM Thread Starter
AlTheKillerr
oh ok. im just glad it wasnt something more serious than a battery. not that i enjoy spending 93 bucks on a battery though
Photographer
2008 X: Strong Fuel Smell Hotreels10 JK Wrangler Technical Forum 13 12-23-2008 01:27 PM
2008 X: Strong Fuel Smell??? Hotreels10 Wrangler General Discussion 0 12-22-2008 08:00 AM
Strong Smell of Gas Typeo28 YJ Wrangler Technical Forum 7 09-10-2005 10:59 PM
Strong exhaust smell?? MBrit13 YJ Wrangler Technical Forum 5 01-10-2005 01:41 PM
Strong gas smell dieseljeep TJ Wrangler Technical Forum 3 10-06-2004 09:38 AM
