Won't start - Doesn't crank - Push starts fine - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Won't start - Doesn't crank - Push starts fine
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 03-06-2010, 06:13 PM   #1
Panici
(O|||||||O)
Panici's Avatar
*Cliffnotes*
-Starter clicks (only once, when I turn my key to run)
-Push starts fine.
-Battery is fine.
-Starter relay and fuse are fine.
-Ground and positive connection to starter solenoid is fine (checked with external cables)
-Screwdriver placed across solenoid terminals yields nothing when the key is off or in run.
Hey guys.
So as these things always go, I had a roadtrip planned for today, and yesterday the jeep started acting up.
I was at the gas station and when I turned the key to start, the starter clicked (once, when I turned my key to run) and I heard some sort of squealing sound.
A minute later, it started up just fine, so i've ruled out the battery.
Today, went to leave for Toronto, and this time it just clicked, no squeeling. Lucky I had 4 people with me and we push started it no problem.
Also push started it leaving UofT, and twice more at both the gas station and McDonalds.
I tried connecting the starter positive with jumper cables to the positive directly on the battery, and no dice there either (with the key on run, and also trying to crank in start)
Thanks for the read,
Panici
_______
|_Jeep_|
(OlllllllO)
590nm Jeep TJ Build+Life
Panici is offline   Reply With Quote Quick reply to this message
Unread 03-06-2010, 06:16 PM   #2
all_clear
Originally Posted by Panici View Post
*Cliffnotes*
-Push starts fine.
-Battery is fine.
Hey guys.
Panici
Sounds like a bad ground or bad starter solenoid.
2004 Jeep Wrangler, Auto Trans, LEDs throughout, 3" Lift, 35" MTZ's
Check out my official RE-build thread. Her name is Ilene
http://www.jeepforum.com/forum/f22/r...ilene-1251802/
all_clear is offline   Reply With Quote Quick reply to this message
Unread 03-06-2010, 07:00 PM   #3
wushaw
Rockin jeep
wushaw's Avatar
Yea you got starter issues.
wushaw is offline   Reply With Quote Quick reply to this message
Unread 03-06-2010, 08:26 PM   #4
Panici
(O|||||||O)
Panici's Avatar
What should I be connecting my jumper cables to test for a bad ground (battery and starter body/mount)?
How can I test for a bad started solenoid?
_______
|_Jeep_|
(OlllllllO)
Unread 03-06-2010, 09:17 PM   #5
wushaw
Rockin jeep
wushaw's Avatar
Just jump from little wire on starter to big wire on starter and see what happens. Make sure you have voltage on big wire.
Unread 03-07-2010, 02:14 AM   #6
Panici
(O|||||||O)
Panici's Avatar
What should happen?
_______
|_Jeep_|
(OlllllllO)
Unread 03-07-2010, 05:58 AM   #7
jeepinmichguy_
get a new starter.
[CENTER][SIZE="4"]ΜΟΛΩΝ ΛΑΒΕ[/SIZE][/CENTER]
[QUOTE=TheBoogieman;12766892]Jeepinmichguy is a jerk.[/QUOTE]
[QUOTE=mrblaine;12000822]
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?[/QUOTE]
[QUOTE=JeepForum123;13578398]you all have nice rigs, stop being f****** a**holes.[/QUOTE]
jeepinmichguy_ is offline   Reply With Quote Quick reply to this message
Unread 03-07-2010, 09:03 AM   #8
all_clear
Before buying a new starter. Check the starter relay. Also i can't remember of the top of my head on the 04. But if your starter and bendix is good then just get the solenoid if they sell it that way. More often then not the starter is good and solenoid just goes bad.
Unread 03-07-2010, 03:39 PM   #9
Panici
(O|||||||O)
Panici's Avatar
Update:
Starter, Solenoid, or both?
_______
|_Jeep_|
(OlllllllO)
Unread 03-07-2010, 03:49 PM   #10
jeepwcrazy
Are you sure your battery connections are fine? I've had mine give the same symptoms that you are explaining and it turned out to be a connection. That system can be a pain in the *** and very frustrating to figure out.
jeepwcrazy is offline   Reply With Quote Quick reply to this message
Unread 03-07-2010, 07:02 PM   #11
Panici
(O|||||||O)
Panici's Avatar
Battery connections are fine. Like I said, I cleaned all of the terminals, tightened, and even applied an external route for the power through some large cables.
_______
|_Jeep_|
(OlllllllO)
Unread 03-07-2010, 07:59 PM   #12
wushaw
Rockin jeep
wushaw's Avatar
Update:
If you had power at the big wire then the starter is bad.
Unread 04-06-2010, 08:36 PM   #13
Panici
(O|||||||O)
Panici's Avatar
Just thought I should update:
Bought a new starter and threw it in. It literally took me 20 minutes to do, including putting the tools away. Fixed the problem, it starts stronger then ever now!
Thanks for the help guys
_______
|_Jeep_|
(OlllllllO)
no start
