Wont go into gear, please help. - JeepForum.com
post #1 of 23 Old 08-08-2010, 02:21 PM Thread Starter
j33p4l1fe4x4
Ok so i dont understand whats going, as of a few days ago, my tj doesnt wanna let me go into gear sometimes. for example, ill come to red light, throw it in neutral, light turns green, and it doesnt wanna go into first, or 2nd, or reverse. same thing happened when i stopped to get gas, and when i went to get something to eat.
anyone know what might be causing this...?
thanks in advance for anyones advice!!!
Wanted: HP30 4.88 / bikini top!!!
j33p4l1fe4x4 is offline
post #2 of 23 Old 08-08-2010, 02:32 PM
wushaw
Rockin jeep
wushaw's Avatar
Yea the clutch is not disengaging from the tranny or all your syncros are worn out or your tranny is out of oil. Check the oil level in tranny and clutch master cylinder.
wushaw is offline
post #3 of 23 Old 08-08-2010, 02:49 PM
OUarmy2012
Did you recently put a body lift on or a t-case drop? because that could be a problem other than that i don't know.
OUarmy2012 is offline
post #4 of 23 Old 08-08-2010, 03:28 PM Thread Starter
j33p4l1fe4x4
t case drop 4 years ago, ok so prolly a scary question but how do you check the oil in the tranny and master cylinder.
post #5 of 23 Old 08-08-2010, 03:37 PM
alilredjeep
alilredjeep's Avatar
Check the reservoir beside the mastercylinder, If its dry, theres your problem.
Eddie
RED JEEP CLUB MEMBER #92
'92 WRANGLER, 2.5 Litre, 5 Speed, Rag Top, Superwinch LP8500, Cepek 130W Driving Lights, 31x10.50/AT with no lift, Of course! It rubs!
alilredjeep is offline
post #6 of 23 Old 08-08-2010, 03:40 PM Thread Starter
j33p4l1fe4x4
lol, and where might i find this mastercylinder, wow can you believe i just asked that and im planning on trying to regear my tj...
post #7 of 23 Old 08-08-2010, 03:46 PM
alilredjeep
Its usually the little white cup looking thing on the firewall usually right beside the brake mastercylinder. Its actually called a slave cylinder thats probably giving you the problem and it mounted on the clutch housing, I beleive, but the reservoir to it is most likely on the firewall right close to the brake mastercylinder.
Eddie
post #8 of 23 Old 08-08-2010, 03:46 PM
wushaw
Rockin jeep
wushaw's Avatar
Can you find the Brake master cylinder under the hood? If so then look to the left of it and down a little, it's small & black, the cap un screws to the left. It's serviced with brake fluid and it's very corrosive to paint, clean up what is spilled.
wushaw is offline
post #9 of 23 Old 08-08-2010, 03:54 PM Thread Starter
j33p4l1fe4x4
ok its its good on fluid, what else could it be?
post #10 of 23 Old 08-08-2010, 03:58 PM
alilredjeep
Sorry I can't help more but if its full, I'm out of ideas for now.
Eddie
post #11 of 23 Old 08-08-2010, 04:07 PM Thread Starter
j33p4l1fe4x4
its ok,, hopefully someone else will be able to, thanks anyways
post #12 of 23 Old 08-08-2010, 04:19 PM Thread Starter
j33p4l1fe4x4
ok maybe this will help, if i PUSH REALLY HARD, it will go into gear.... any more ideas guys???
post #13 of 23 Old 08-08-2010, 04:27 PM
wushaw
Rockin jeep
wushaw's Avatar
Hard??? I must be missing something here.
Is the clutch pedal going to the floor when you push it?
Is it taking more pressure to push it than it did when you bought the jeep?
wushaw is offline
post #14 of 23 Old 08-08-2010, 04:31 PM Thread Starter
j33p4l1fe4x4
push hard on the stick, like i have to force it into 1st, the clutch seems fine. i push it in like i always do, it doesnt feel any different
post #15 of 23 Old 08-08-2010, 04:33 PM Thread Starter
j33p4l1fe4x4
also if i let it roll back some it will let me put it in gear....
gear , wont engage , resistance , tj , wrangler , manual , standard , transmission , tranny , stuck
Wont Go In Gear!!!!! nickoidl YJ Wrangler Technical Forum 7 06-12-2010 08:51 PM
Wont go into gear CapeCodGuy YJ Wrangler Technical Forum 23 04-20-2010 08:21 AM
Wont go into gear need help!! Toady TJ Wrangler Technical Forum 4 12-23-2008 10:37 AM
Wont Go into Gear fogertyb TJ Wrangler Technical Forum 3 07-21-2008 01:29 PM
Wont go into gear Nukeproof YJ Wrangler Technical Forum 9 01-29-2003 03:01 PM
