Quantcast Wont Go into Gear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Wont Go into Gear
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 07-21-2008, 10:13 AM   #1
fogertyb
Wont Go into Gear
As i pulled off the highway yesterday, i pulled it out of 5th gear, then i went to put it into another gear as i made a turn and it would not go into gear, so i tried another gear, and then another and then i just pulled over, now the stick will move side to side, and it rolls freely but it will not go into gear, im goign to drop the tranny tonight and try and figure it out (my dad used to build trannys, and he thinks it might be the something with the overdrive not lining up right and its not lettign it go into gear)
anyone had this problem before, its a 97 5 spd
I bought my jeep in mid may '08; ever since then my girlfriend complains i spend to much time working/playin with my jeep....She says, "I'v Been Replaced by a jeep :("
R.I.P Nathan Fogerty
fogertyb is offline   Reply With Quote
Old 07-21-2008, 10:30 AM   #2
Rubicon_TJ
If you have had no hints of clutch issues or shifting problems prior to this...
then a tear down will be a "fun" adventure to solve the mystery.
I'm guessing you have already done the easy stuff, like making sure the clutch hydraulic fluid is full, inspecting clutch linkage, and checking transmission fluid quality/levels to find any possible clues.
I just got done replacing the clutch on mine - dropping the transmission/t-case combo was a good bit of work!
Good luck with quickly finding the problem and the solution.
2003 Bright Silver Rubicon
285/70/17 Goodyear Kevlar MT/R's, OME, DIY bumpers/roll cage upgrades,
Champion beadlocks, 33Eng BellyUp w/CV shaft, JKS BL&MML
Rubicon_TJ is offline   Reply With Quote
Old 07-21-2008, 10:52 AM   #3
fogertyb
yeah, the clutch is fine, nothin is locked up, and its full of fluid and moves freely from side to side, but it will not go into gear, its def. the tranny, so it shall come out either tonight or tomorrow, good thing my grandma doesnt drive her car much and i can take it to work!
Old 07-21-2008, 01:29 PM   #4
Rubicon_TJ
I wonder if it could be one of the shifter forks.
One of my wheeling buddies has an eighties-something XJ with a weak five speed. His transmission is worn to the point that the shifter forks pop out of place if he tries apply any significant pressure to shift it.
Glock Forum
