Quantcast wont go into 2nd gear - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > wont go into 2nd gear
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 02-19-2009, 12:32 PM   #1
DOWE
after i put on my suspension lift i was going to drive it out of the shop and the shifter boot restricted it from going into second gear.I had to take it off so it can go into second gear alright but still seems like the surrounding plastic is in the way.did i do something wrong? what can i do to fix it?
i could really use some help
DOWE is offline   Reply With Quote
Old 02-19-2009, 12:41 PM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
I would guess the Bl is the problem and you need to bend the tub below the shift boot a little.T case drop will do the same thing.
p.s. Your post count is higher than Obama's stimulus package.
TheBoogieman is offline   Reply With Quote
Old 02-19-2009, 12:45 PM   #3
DOWE
thanks man i appreciate it..im guna go do that right now hah
Old 02-19-2009, 12:47 PM   #4
DOWE
how would i go about bending this? should i take it out?
Old 02-19-2009, 01:57 PM   #5
RUBtjICON
Pull the center console out, and bend the metal around the shifter hole. If it has been hitting, you should see where you need to make alterations.
2004 TJ Rubicon........My build thread, My URE Vid
www.vanc4x4.net
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline   Reply With Quote
Old 02-19-2009, 02:21 PM   #6
NavinRJohnson48
i had the exact same problem after installing my 3.5RE lift. when you dropped the t-case it lowered the shifter. i just took the boot and plastic surround out of the console and left it as a hole. yeah i sometimes lose change to the black hole but whatever, it's a jeep, not a wallet. there's probably a few fries down there too. i'm planning on a jb ss/sye so i'll be able to bring the case back up soon enough and re-install the boot and plastic.
NavinRJohnson48 is offline   Reply With Quote
Old 02-19-2009, 02:47 PM   #7
uscgjp
I get a similar issue in 2nd and 4th - pops out sometimes if I haven't slammed it into gear. Makes sense now.
"Hit it with blaster for six weeks."
- Really? Wow... that would have helped...
Blue Jeep Club Member #272
uscgjp is offline   Reply With Quote
Old 02-19-2009, 03:29 PM   #8
Dmcastino
You might also thinking about moving the center console back a little. And Boogie is right, WTF is up with your post count?
Dmcastino is offline   Reply With Quote
Glock Forum
