Won't start - Doesn't crank - Push starts fine - JeepForum.com
post #1 of 13 Old 03-06-2010, 06:13 PM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
*Cliffnotes*
-Starter clicks (only once, when I turn my key to run)
-Push starts fine.
-Battery is fine.
-Starter relay and fuse are fine.
-Ground and positive connection to starter solenoid is fine (checked with external cables)
-Screwdriver placed across solenoid terminals yields nothing when the key is off or in run.
Hey guys.
So as these things always go, I had a roadtrip planned for today, and yesterday the jeep started acting up.
I was at the gas station and when I turned the key to start, the starter clicked (once, when I turned my key to run) and I heard some sort of squealing sound.
A minute later, it started up just fine, so i've ruled out the battery.
Today, went to leave for Toronto, and this time it just clicked, no squeeling. Lucky I had 4 people with me and we push started it no problem.
Also push started it leaving UofT, and twice more at both the gas station and McDonalds.
I tried connecting the starter positive with jumper cables to the positive directly on the battery, and no dice there either (with the key on run, and also trying to crank in start)
Thanks for the read,
Panici
_______
|_
_|
(OlllllllO)
Panici is offline
post #2 of 13 Old 03-06-2010, 06:16 PM
all_clear
Originally Posted by Panici View Post
*Cliffnotes*
-Push starts fine.
-Battery is fine.
Hey guys.
Panici
Sounds like a bad ground or bad starter solenoid.
2004 Jeep Wrangler, Auto Trans, LEDs throughout, 3" Lift, 35" MTZ's
Check out my official RE-build thread. Her name is Ilene
all_clear is offline
post #3 of 13 Old 03-06-2010, 07:00 PM
wushaw
Rockin jeep
wushaw's Avatar
Yea you got starter issues.
wushaw is offline
post #4 of 13 Old 03-06-2010, 08:26 PM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
What should I be connecting my jumper cables to test for a bad ground (battery and starter body/mount)?
How can I test for a bad started solenoid?
_______
|_
_|
(OlllllllO)
Panici is offline
post #5 of 13 Old 03-06-2010, 09:17 PM
wushaw
Rockin jeep
wushaw's Avatar
Just jump from little wire on starter to big wire on starter and see what happens. Make sure you have voltage on big wire.
wushaw is offline
post #6 of 13 Old 03-07-2010, 02:14 AM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
What should happen?
_______
|_
_|
(OlllllllO)
Panici is offline
post #7 of 13 Old 03-07-2010, 05:58 AM
jeepinmichguy_
get a new starter.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #8 of 13 Old 03-07-2010, 09:03 AM
all_clear
Before buying a new starter. Check the starter relay. Also i can't remember of the top of my head on the 04. But if your starter and bendix is good then just get the solenoid if they sell it that way. More often then not the starter is good and solenoid just goes bad.
post #9 of 13 Old 03-07-2010, 03:39 PM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
Update:
Starter, Solenoid, or both?
_______
|_
_|
(OlllllllO)
Panici is offline
post #10 of 13 Old 03-07-2010, 03:49 PM
jeepwcrazy
jeepwcrazy's Avatar
Are you sure your battery connections are fine? I've had mine give the same symptoms that you are explaining and it turned out to be a connection. That system can be a pain in the *** and very frustrating to figure out.
jeepwcrazy is offline
post #11 of 13 Old 03-07-2010, 07:02 PM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
Battery connections are fine. Like I said, I cleaned all of the terminals, tightened, and even applied an external route for the power through some large cables.
_______
|_
_|
(OlllllllO)
Panici is offline
post #12 of 13 Old 03-07-2010, 07:59 PM
wushaw
Rockin jeep
wushaw's Avatar
Update:
If you had power at the big wire then the starter is bad.
wushaw is offline
post #13 of 13 Old 04-06-2010, 08:36 PM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
Just thought I should update:
Bought a new starter and threw it in. It literally took me 20 minutes to do, including putting the tools away. Fixed the problem, it starts stronger then ever now!
Thanks for the help guys
_______
|_
_|
(OlllllllO)
Panici is offline
no start
Battery is fine but engine will not crank. had to roll it back in forth then try... Mitchin TJ Wrangler Technical Forum 12 11-20-2009 09:49 AM
99 TJ Sport - Crank, No Start, Ran Fine before. redroof TJ Wrangler Technical Forum 3 10-14-2009 08:04 AM
Starts, Idles, Dies, Wont Start, Wont Start, Pump Pedal, Starts... REPEAT inniett YJ Wrangler Technical Forum 2 04-08-2009 04:13 PM
6cyl. Starts fine then dies? Whats the prob? brianOU YJ Wrangler Technical Forum 4 09-07-2008 06:51 PM
Push start a TJ jzmtl TJ Wrangler Technical Forum 21 09-12-2006 03:45 PM
