Wobble . Shimmy in Steering Wheel at 40-50MPH? - JeepForum.com
post #1 of 9 Old 05-15-2007, 06:19 AM Thread Starter
fourtwenty
I can feel side to side pulling in the steering wheel between 40 and 50 MPH. it started after I put on a set of 265/75R16 TrXus MTs mounted on 16x8 Rockcrawler rims. I am running a 2" BB with OME shocks on a 2003 Rubicon.
Any idea what this is? Could it be a balance issue?
Thanks
Edit: just had all 4 tires balanced and they are about as close to perfect as you can get. The wobble is still there. It's started since I put the TrXus tires on. It was perfectly fine with a set of 245/75R16 BFG ATs. I guess I'll have to crawl under there again and double check that everything is torqued to spec.
The alignment was done when I put the BB on in the fall, and it tracked fine until I put these tires on. Could it be something to do with the tires, even though they balance fine?
Any other suggestions?
Current Jeep: 2012 Wrangler Unlimited Sahara
Past Jeeps: 2004 WJ Limited, 1999 Cherokee, 2003 Rubicon, 1987 Cherokee, 1976 CJ5, another 1987 Cherokee, 1976 CJ7, 1983 CJ7, 1977 CJ5, 1982 CJ7.
fourtwenty is offline
post #2 of 9 Old 05-15-2007, 06:21 AM
nyoffroad
Balance or allignment. Im sure someone else will chime in soon with the the web site that has a good write up on doing your allignment yourself, im not sure what it is.
3"Blackdiamond susp. lift
basic skid plates
Bushwacker brush and rocker guards
Rock-it air intake
more to come in future
nyoffroad is offline
post #3 of 9 Old 05-15-2007, 06:23 AM Thread Starter
fourtwenty
I had an alignment done in th fall, and it was driving straight before I put the new tires on. I'm leaning towards getting the tires balanced again, just wanted to see if someeone thought it might be something else.
post #4 of 9 Old 05-15-2007, 06:35 AM
MikeWL
MikeWL's Avatar
Balance the tires again and it should go away. I have that same thing show up every now and then and balancing always fixes it.
[B]2001 TJ Sport - 4.0L/5-sp, locked Dana 44's, 4.10, 33's, Mile Marker; 2000 TJ Sport RIP
MikeWL is offline
post #5 of 9 Old 05-25-2007, 02:53 PM Thread Starter
fourtwenty
I just had all 4 tires balanced and they are about as close to perfect as you can get. The wobble is still there. It's started since I put the TrXus tires on. It was perfectly fine with a set of 245/75R16 BFG ATs. I guess I'll have to crawl under there again and double check that everything is torqued to spec.
post #6 of 9 Old 05-25-2007, 02:55 PM
06rubicon
2017 JK Wrangler
Rotate the front tires to the rear and test drive it again!
06rubicon is offline
post #7 of 9 Old 05-26-2007, 01:26 AM
TJ=MT Pockets
make sure the trac bar is tight and all other bolts too.
Y2K 4L 5spd TJ Sport--4.5" RE SF all adj. arms--1" BL--1" MML--33"bias swampers(soon to be 36" swamper sx's on rockcity diy beadlocks)--D44 4.88's arb w/alloy usa shafts--HPD30 4.88's locrite w/warn alloy inners--warn small hub kit--longfield hd u-joints--currie steering--currie anti-rock--tera low--A-Z Fab cage--and a bunch of skids
TJ=MT Pockets is offline
post #8 of 9 Old 05-28-2007, 03:56 AM
MZP
Great tires, but have heard they are hard to balance.
MZP is offline
post #9 of 9 Old 05-28-2007, 06:14 AM Thread Starter
fourtwenty
According to the balancing machine they are balanced almost perfect (I watched them do it). One tire needed 4.5 oz, the rest were under 3 oz.
steering wheel shimmy rsant39 TJ Wrangler Technical Forum 6 08-11-2012 04:29 PM
Lifted now sterring wheel wobble at 40-50mph DirtDiver TJ Wrangler Technical Forum 17 05-14-2010 02:54 PM
Steering Wheel Shimmy at 45 mph after 2" Budget Boost. Suggestions? hddeuce TJ Wrangler Technical Forum 2 11-14-2009 09:39 PM
steering wheel shimmy when going over bumps rmb2485 TJ Wrangler Technical Forum 13 07-31-2007 05:39 PM
Finally installed my BB, now it has a shimmy around 40-50mph after alignment fourtwenty TJ Wrangler Technical Forum 8 09-04-2006 10:26 PM
