Wiring LED turn signals/marker lights - JeepForum.com
post #1 of 2 Old 03-14-2008, 04:36 PM Thread Starter
chandlerr
chandlerr's Avatar
I tried wiring up my led turn signals today and got the left turn signals working fine. Then I moved on to the right and realized that if I hooked up the marker light on the right side that the marker light would light up if the headlights were not on but they would go dim when the headlights turned on (with one click on the steering column they light up, 2 clicks they dim) The left marker light worked fine though... for background info, I just replaced the headlights with hella lights and found out at the same time that the left headlight doesn't light up all the way but the right headlight lit up fine. My question is does anyone know what the deal is, are the headlights and marker lights related?
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs, 37" Iroks (lost to Mexico. RIP Krystal)
2006 Black LJ Rubicon, stock suspension w/ 33's
chandlerr is offline
post #2 of 2 Old 03-14-2008, 06:19 PM
deltabravo
Sounds like the headlight has a bad ground - the one that is DIM.
deltabravo is offline
damaged hitched wiring no turn signals now 2005LJRubicon TJ Wrangler Technical Forum 1 01-29-2010 03:32 PM
TJ side marker turn signals - any ideas? cherokee980 TJ Wrangler Technical Forum 0 12-03-2008 11:01 AM
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
Electrical problem, turn signal/marker light wiring jeeptillidie TJ Wrangler Technical Forum 13 01-30-2008 10:41 AM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 08:18 PM
