#1 | ||
Wiring a hitch
smokeeman33 '06 TJ |
#2 |
Here is an example of what you are looking for though its a 2007. You just need to look for a correct tj harness for your year.
I googled "jeep 7 way trailer tow harness" Last edited by Rubi Unlimited; 07-12-2007 at 07:14 PM. |
#3 |
Just go to your local Jeep Dealership and ask for the wiring, I did the same thing. It cost about $35 and was a simple install. The plug uses the existing wiring that is stored behind your passenger rear tire and simply just plugs in. It comes with all the necessary zip ties and replacement snaps.
2002 TJ Sahara, 4.0L, I6, 5 speed manual, RE 4.5 SF w/ 4.5 springs, RE Monotube shocks, 33" MTZ's, 15 x 8 black wheels, RE GEN II quick discos, Warn M8000 winch, LoD Rocker Guards, LoD Xtreme tire carrier, High Jack Lift, Dual Top, Viper 5000 alarm ___oooo_ [l_, [____], l---L -OlllllllO- ()_) ()_)=0=)_) |
#4 |
Pricey
Yep that's it. I read Mopar was pricey but they could be found for around $20. I guess I just need the four way since I only pull a '10 foot trailor with a couple of dirt bikes. Thanks for the reply.
#5 |
Yep I think mine is the 4 way mopar one too... It really is a simple install, I got fancy and drilled some holes to mount the bracket that comes with it to my bumper, but it is probably a 10 min job
#6 |
Anybody have a factory TJ part number for this ?
#7 |
part # 82208579 1998-2004
part # 82209183 2005-2006 http://jparts.com/product_info.php?products_id=1413&osCsid=39282851a c7d9ed1bb752f4db512d994 ![]() |
#8 | |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Hitch Wiring - How to mount wires on hitch | WaldenL | JK Technical Forum | 6 | 08-19-2009 09:10 PM |
| hitch wiring | legend6009 | TJ Technical Forum | 1 | 04-26-2008 11:58 AM |
| Flush Hitch Install = Hitch + Wiring seamless? | pwygant | JK Technical Forum | 2 | 12-20-2007 09:45 AM |
| Hitch/wiring help | ballardsj | YJ Technical Forum | 2 | 12-19-2005 03:21 PM |
| Tow Hitch wiring | Baas | TJ Technical Forum | 11 | 10-12-2005 11:52 PM |
The time now is 07:28 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
