Wiring harness compatibility - JeepForum.com
post #1 of 2 Old 07-24-2010, 01:02 AM Thread Starter
MrRage
I need an engine wiring harness for a 99 Jeep wrangler, 4.0L. But I've been having a hell of a time finding one for that year in the configuration I need. I'm finding a lot of stuff thats either 98 or newer/older than 99.
From the looks of it the 97-99 engine compartments look the same. Things are in the same spot and the 99 has not switched over to the spark rail yet either. So I'm almost willing to take a chance on a 98...
I'm going to try to fix it first but its not exactly a small portion of harness. I have to splice in a whole new section starting at the front of the block and spliceing it in somewhere in the back of the block. Really it should be a few inches passed that section because thats where the service manual noted it was recommended to splice there.
A little crispy, wouldn't you say?
MrRage is offline
post #2 of 2 Old 07-24-2010, 01:11 AM
JarrettJones
Are those wires ran over the header? There should of been a plastic retainer piece to keep the wires off the header. I would repair the harness and buy the part that hold the wires off the header. Yes it seem like spliceing in new wires will be a pain, but $20 for wire and crimps beats the $100s for a new harness any day.
JarrettJones is offline
wiring harness , compatibility , tj , wrangler , help
What is this goo at my wiring harness? Fernando YJ Wrangler Technical Forum 2 06-15-2009 09:41 AM
how is your wiring harness run? snowrydr01 TJ Wrangler Technical Forum 3 08-22-2008 04:52 PM
wiring harness gfortier YJ Wrangler Technical Forum 2 06-06-2008 06:21 AM
wiring harness TJdave TJ Wrangler Technical Forum 1 08-10-2006 01:47 AM
4.0 HO wiring harness sasquatch3805 YJ Wrangler Technical Forum 1 07-31-2005 09:12 PM
