Wiring Aux Lights with Contura Switch
| DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series |
#1 | |
I want to wire my aux lights and misc electronics through a fuse block. I am planing on getting the bussman fuse block from OTRATTW, but am open to suggestions.
Here is a wiring diagram that I made, I need to know if it is accurate and which wire to connect to position 6 (Lower Light Pos) on the switch. It should be either the positive from the power/fuseblock or the positive from the lights, although I am leaning to the one from the power. ![]() Thanks for any help guys!
#2 |
You would probably get a better responce in the electrical section.
Can't tell you about the switch pole numbers as I have no idea what they are. I'm pretty sure the 8 and 7 would not go to the light. They would go to ground, as they are likely to give the switch ground for the light. Ground from light can go to frame ground close to the light rather than running the wire from the battery, fuse block, etc. You should also have a relay in between the switch and the lights, depending on the amp rating of the switch you might be able to run it without the relay but best practice is to have that relay. Last edited by XXRider; 08-29-2008 at 12:21 AM.. Reason: Added more info |
#3 |
If you have the ARB style Contura, here's what I did with my sPod:
![]() Where it shows "SW1", etc., is the feed to the relays for the accessories. It's always a good idea to run a relay. Your in-cab switches would be low current and the relays, out of cab, would be the high current to the accessories. On my Conturas, they have two lights in the switch body, one for dash lamp and the other illuminates when the switch is on. There is only one power wire (terminal #3) that would run the accessory. ![]()
DON'T FEAR THE RE-GEAR!!!
______ |_____| (O|||||||O) |______| []===o==[] RED JEEP CLUB MEMBER #430 |
#4 |
10-4 on the relay. I just wired my aux lights with the contura switches. I did not wire the upper light (too bright and you can see white light behind the switch rocker). You can run the same power to both the 2 and 6 location on the switch. If you only want the light on when you turn your headlights on you will have to find one of the wires that run to your dash lights. I just ran all of mine to a keyed ignition wire so that there is only poer to them when the key is on. You really don't need the fuse block. As long as your aux lights come with the relay you can just pull power from the cig lighter in the dash and run it to power all of you switches. I also wired my winch controls into my cab and using the keyed wired, you cannot operate the winch without the key on. Here's how mine turned out. The lower lights come on when the ingition is on. The upper lights are not wired to be on at any time. The winch in/out button only lights up when the "arm" button is on.
![]() Here is what mine looks like. |
#5 |
thanks for the help, i just discovered the electrical thread also so that should help. I butchered the wiring behind the dash when i hooked up my cb and want to do things clean and right this time, so thats the reason for the fuse block.
Also I want the power to be ignition on only, so where would I get enough power for the lights that would work. Thanks again. |
#6 |
Exactly what kind of lights are you hooking up? You should not be running the full power wire for your lights through the switch. The switches are fairly low voltage/amperage and should send power to a relay (should be included with the light kit). Once power is sent to the relay, the relay switches full power to the lights directly from your battery. You only need to find a wire that that is on when the key is on. I used the power wire to the cig lighter. It is already fused and you won't draw much current from it to activate a relay.
Also, most light kits have an in-line fuse, eliminating the need for a fuse block. |
#7 |
i bought some kc daylighters a while ago without a kit, so im going to have to buy the fuse block and the relay
#8 |
edited the diagram, it's in the first post. robncar's diagram helped a lot but what is position 2, is it the power for the switch lights?
#9 | |
#2 is the power "in" to the large upper switch lamp AND is switched out through #3. This will trigger the relay for your accessory (load), in your case lights. In my application, switch 5 is only ON if switch 4 is ON. Switch 6 will be ON only if switch 4 and 5 are ON. The same functionality as the ARB harness. I would recommend a fuse between #2 and Bat (or other + source) also. Even though it's only a switch circuit with a small lamp, controlling a relay, it's always good practice to fuse.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
