Wipers wont turn on - JeepForum.com
post #1 of 7 Old 10-17-2013, 06:02 PM Thread Starter
mtber7828
Wipers wont turn on
I have a 97 tj and I just tried to turn on the wipers today and nothing. They have not slowed down prior or have I noticed anything out of the ordinary. Everything else on the colum works. The washer still squirts. I checked the tiny fuse behind the glovebox and it is good. Any idea of what I should do now? Thank you
mtber7828 is offline
post #2 of 7 Old 10-18-2013, 11:42 AM
Jonny Jeep
Jonny Jeep's Avatar
Do the turn signals and radio work when the wiper doesn't? They are all fed from the same set of contacts in the ignition switch, so if they are out too either the switch is bad or the fuse supplying the switch is bad. that would be fuse 3 under the hood.
Could be the motor but you'd need to remove the cowl panel to get to that.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #3 of 7 Old 10-18-2013, 11:52 AM
Tblack
Those windshield motors go out all the time.
Safety 3rd!
Tblack is offline
post #4 of 7 Old 10-18-2013, 01:32 PM
Jonny Jeep
Jonny Jeep's Avatar
didn't notice the "washer still works" earlier. It'll be the motor then.
post #5 of 7 Old 10-18-2013, 08:04 PM Thread Starter
mtber7828
Today they still wouldn't work so I gave the steering colum a few taps on the top and the wiper started working. I'm thinking it might be the switch/lever that's going bad. Anyone ever change one
post #6 of 7 Old 10-19-2013, 07:40 AM
Jonny Jeep
Jonny Jeep's Avatar
I've changed one. But not because the switch wasn't working. I replaced my non intermittent switch for one with the intermittent function.
They are pretty easy to swap. Having a non tilt column, I find removing the top half of the steering column cover is easier if the cluster surround is removed.
post #7 of 7 Old 10-19-2013, 08:15 AM
Navydoc1
I did the same thing, took less than an hour , not a hard job at all
Navydoc1 is offline
