Wipers start when I start the jeep - JeepForum.com
post #1 of 4 Old 09-07-2005, 08:26 PM Thread Starter
Rock & Roll
Searched it and couldn't find my problem...
When I start my Jeep after it sitting outside overnight (humid nights here) my wipers will turn on (without moving the arm) for about 2-3 minutes then stop automatically and function normally.
Doesn't sound like the typical motor burn out.
Red 97 4.0 5 spd| 4" Procomp, stage II | 33" Bfat's | Bestop Half top | Bestop Tire Carrier | Gibson cat back | JKS Discos
SYE & CV | RE Rear Upper adj control arms | Mountaineer rack | Chrome Options | Infinity Perfect System w/ 12"
Just threw in a D44, with an Eaton E-Locker, 4.56 Gears, and a poision spider diff cover to boot!
Check out
Rock & Roll is offline
post #2 of 4 Old 09-07-2005, 08:35 PM
BlueTorch
sounds like the switch to me. You can get some contact cleaner from Radio Shack and spray that in the switch. Costs like 5 dollars for a small can. Has worked for me on a couple things.
-Dan
Blue Torch FabWorks, Inc.
205-521-7333 OR 866-RCK-CRWL
Check out our Facebook fan page!
[SIGPIC][/SIGPIC]
BlueTorch is offline
post #3 of 4 Old 09-07-2005, 08:52 PM Thread Starter
Rock & Roll
-Dan
Switch on the steering column?
Check out
post #4 of 4 Old 09-07-2005, 11:12 PM
stedwest
Check for a bad grounds. That is frequently the culprit.
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
stedwest is offline
Wipers come on when I start it 97 TJ tlendt TJ Wrangler Technical Forum 0 06-16-2009 07:39 PM
TJ wipers stop and start bayouguy TJ Wrangler Technical Forum 0 06-15-2009 09:31 PM
no start/crank/wipers/blinkers 87 4cyl richharr YJ Wrangler Technical Forum 2 01-19-2009 11:57 AM
Jeep won't start - Starter doesn't start cooltc2004 YJ Wrangler Technical Forum 5 12-29-2008 11:36 AM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 09:28 AM
