Windstar cowl intake - Page 8 - JeepForum.com
 1Likes
post #106 of 254 Old 08-18-2011, 01:27 PM
Pillswoj
A link to that reducing elbow would be great, it is a lot cleaner looking then the pvc pipe I used as well.
Friends don't let Friends run Bosch
Pillswoj is offline
post #107 of 254 Old 08-18-2011, 01:46 PM
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
I did a similar intake and then o the full blown H1 style snorkel..
http://www.jeepforum.com/forum/f9/co...ction-1043265/
and I saw about 1 MPG increase... I did it to raise the intake... lots of deep water / mud down here!
http://www.jeepforum.com/forum/f9/h1...ntake-1047417/
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion, SOLD!) 89' Int. Harvester Toter (SOLD)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process/million pieces) 2000Kenworth Hauler
j_bydesign is offline
post #108 of 254 Old 08-18-2011, 07:52 PM
sduncan
sduncan's Avatar
http://intakehoses.com/Merchant2/mer...ory_Code=R9DEN
'98 TJ, 5.7 HEMI,
sduncan is offline
post #109 of 254 Old 08-31-2011, 10:54 PM
rs4race
Thanks for this writeup. I picked up the windstar intake today for $20 and will be installing it tomorrow. I will be using 2.5" aluminum tubing with header wrap instead of the stock intake though.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #110 of 254 Old 09-01-2011, 07:22 AM
midnight_f150
please post some picture when your done.
midnight_f150 is offline
post #111 of 254 Old 09-01-2011, 07:54 AM
angelo2975
Originally Posted by ncbluetj View Post
Is that some sort of heat shield under your intake manifold?
The shield was a TSB too prevent the "hot soak issue" that the TJ had ...the #3 Injector would have intermittent operation due to the amount of heat it was exposed too. It happen usually right after a long drive or stop and go traffic...you turn off the jeep and if you started back up within an half an hour it would misfire until the heat would dissipate from the injector. adding louvers to the hood also help correct the problem
angelo2975 is offline
post #112 of 254 Old 09-10-2011, 12:56 AM
lpukas2
Hole
What size hole did you guys drill into your firewall, I did not see it address an this thread.
lpukas2 is offline
post #113 of 254 Old 09-10-2011, 08:55 AM
biffgnar
biffgnar's Avatar
Originally Posted by lpukas2 View Post
what size hole did you guys drill into your firewall, i did not see it address an this thread.
3"
biffgnar is offline
post #114 of 254 Old 09-15-2011, 06:45 PM
lpukas2
Has anyone did this with a 1" motor mount lift?
lpukas2 is offline
post #115 of 254 Old 09-17-2011, 01:28 PM
mystangt
I had it on my old 97, worked fine
mystangt is offline
post #116 of 254 Old 09-17-2011, 01:42 PM
biffgnar
biffgnar's Avatar
Yep. No problems.
biffgnar is offline
post #117 of 254 Old 09-17-2011, 03:00 PM
rs4race
Here we go. It turned out pretty good imo. Gas mileage has seemed to go up but I may just be easier on the throttle. I used some 2.75" aluminum tube from a greddy intercooler. I wrapped it up with some header wrap.
My Build
rs4race is offline
post #118 of 254 Old 10-03-2011, 11:47 PM
dcope17
Okay... my turn for a question. 3" hole into the fire wall, what is that hose piece from that goes into the firewall?
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #119 of 254 Old 10-04-2011, 04:16 AM
athos76
The funnel looking piece comes off of the Windstar donor vehicle. You can find it sticking through the quarter panel into the wheel well area.
I used 2 3" adapter flanges from the auto parts store and a 4" to 3" reducing elbow ordered from intakehoses.com. I also had to adapt the crankcase breather to it which was probably the most difficult part since the stock intake tube is so thick.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #120 of 254 Old 10-04-2011, 06:05 AM
rikkards
rikkards's Avatar
Originally Posted by mystangt View Post
As much as the cooler air will help, a straighter intake tube will go a longggg way to make it that much better.
Countless tests have proven that a straighter intake tube will yield the same if not more gain than cooler air. Now, combine the 2 and you may really feel te difference.
Google JLT intakes. They have done extensive research about this.
Hell, any HVAC guy will tell you that. Every 90* turn is equivalent to having 8 extra feet of ductwork.
rikkards is offline
cowl , intake , TJ
Cowl Intake with Windstar air box Hapytruck01 TJ Wrangler Technical Forum 22 04-04-2012 06:51 PM
Cowl Air intake schu TJ Wrangler Technical Forum 2 04-22-2009 08:55 PM
Help with Cowl Intake BDAZCJ5 TJ Wrangler Technical Forum 22 08-14-2005 08:21 AM
Cowl Intake bigblackblur TJ Wrangler Technical Forum 8 02-13-2005 09:37 PM
cowl intake Bucket110 TJ Wrangler Technical Forum 1 10-17-2003 09:00 AM
