Windstar cowl intake - Page 7 - JeepForum.com
 1Likes
post #91 of 254 Old 06-23-2011, 02:09 PM
rs4race
anyone ever think about how hot the intake manifold gets from the exhaust being so close? I bet isolating the two could be an idea worth a little power.
This is something that I will be working on in this summer. Maybe make some money to wheel more.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #92 of 254 Old 07-31-2011, 05:35 PM
sduncan
sduncan's Avatar
Ok...I'm pretty much sold on the OPs version of the Windstar intake. This is mostly due to the fact that I need more room under the hood on the fenderwell for a future add-on. My actual question is this....would a cowl scoop be beneficial in helping keep water out and if so, should it be facing forward or back towards the windshield?
This is the one I am considering.
http://www.rampagejeepaccessories.co...-Wrangler.html
Thanks....
'98 TJ, 5.7 HEMI,
sduncan is offline
post #93 of 254 Old 07-31-2011, 05:54 PM
biffgnar
biffgnar's Avatar
Thanks....
I put one on facing the windshield. I think it does help keeping water out, although honestly I don't think you have a real risk even without it.
Romney in 2020!
biffgnar is offline
post #94 of 254 Old 08-03-2011, 06:41 PM
sduncan
sduncan's Avatar
Ok.. one more question but I think I know the answer from looking at the pics. I'm just wanting to double check...Any issues with the auto trans dip stick. It looks like its going to be VERY close if not right in the way of the air canister. I know I could probably bend it slightly but would rather know ahead of time if its a fit like it is.
Thanks
'98 TJ, 5.7 HEMI,
sduncan is offline
post #95 of 254 Old 08-03-2011, 07:48 PM
sduncan
sduncan's Avatar
Here's where I'm at so far. I just have to cut the hole and am waiting on the reducing 90 to arrive.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #96 of 254 Old 08-03-2011, 09:40 PM
biffgnar
biffgnar's Avatar
Thanks
You may have to bend it a little. No big deal.
Romney in 2020!
biffgnar is offline
post #97 of 254 Old 08-03-2011, 10:40 PM
reddirtTJ
I just finished this mod. Not too bad for around 45 bucks. You can hear it whenever you throttle hard, but under normal driving conditions I do not notice it. Thanks for the idea. Now for hood louvers.
97 TJ 4.10s, 33s, 4" Clayton.
"TJ's and CJ's are Jeeps. BJ's are something else entirely. I can only help you with the first two." Sundowner
reddirtTJ is offline
post #98 of 254 Old 08-04-2011, 06:36 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Very nice. Love the "color matched" elbow.
Whybu1 is offline
post #99 of 254 Old 08-04-2011, 05:55 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
If you get water up to the top of the cowl then you will want to install a snorkel instead.
Group W Bench
CRAWLING 98 is offline
post #100 of 254 Old 08-04-2011, 06:20 PM
biffgnar
biffgnar's Avatar
Agreed, but flooding the cowl is not something I expect to do. I really don't like snorkels.
Romney in 2020!
biffgnar is offline
post #101 of 254 Old 08-04-2011, 06:23 PM
Benderff
Benderff's Avatar
You have worse problems if you are in water that deep.
Benderff is offline
post #102 of 254 Old 08-04-2011, 09:20 PM
sduncan
sduncan's Avatar
I wheel in the same type of areas as that in your avatar. Water flooding over the cowl is one of the last things I'm worried about.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #103 of 254 Old 08-10-2011, 06:34 PM
sduncan
sduncan's Avatar
Well its done and turned out pretty good. Now to drive it a little and see if any issues pop up. I had no problems bending the auto trans fill tube to the side for clearance.
One note...Be sure to drill the 3in hole into the cowl area low enough so that the new air cleaner clears the hood when closed. I almost screwed up there but caught it beforehand.
Thanks to all for posting pics and advice.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #104 of 254 Old 08-18-2011, 11:57 AM
rs4race
Is that 90* bend reduction from the windstar also?
My Build
rs4race is offline
post #105 of 254 Old 08-18-2011, 11:59 AM
biffgnar
biffgnar's Avatar
There was nothing like that attached to my windstar box when I got it. I used a 90* PVC pipe with rubber reducing rings on each end for me.
Romney in 2020!
biffgnar is offline
cowl , intake , TJ
Cowl Intake with Windstar air box Hapytruck01 TJ Wrangler Technical Forum 22 04-04-2012 06:51 PM
Cowl Air intake schu TJ Wrangler Technical Forum 2 04-22-2009 08:55 PM
Help with Cowl Intake BDAZCJ5 TJ Wrangler Technical Forum 22 08-14-2005 08:21 AM
Cowl Intake bigblackblur TJ Wrangler Technical Forum 8 02-13-2005 09:37 PM
cowl intake Bucket110 TJ Wrangler Technical Forum 1 10-17-2003 09:00 AM
