Windstar cowl intake - Page 6 - JeepForum.com
 1Likes
post #76 of 254 Old 06-10-2011, 12:35 PM
JeffBowser
I'd love to see mine that clean again, but I don't think that's in the cards.
JeffBowser is offline
post #77 of 254 Old 06-10-2011, 12:41 PM
Deacon
Shining Adonis
Deacon's Avatar
Originally Posted by sh13lds21 View Post
i agree with you about that the stock system flows enough air but imo its pretty restrictive
These two things cannot be simultaneously true. Please re-evaluate your statements.
Deacon is offline
post #78 of 254 Old 06-10-2011, 12:43 PM Thread Starter
sh13lds21
yeah it didnt take long cause mine was hardly dirty but my cummins was always filthy and when i would clean that i just took it to the car wash pressure washed it off and went and got some kind of cheap spray on wax that is ok for belts and stuff and sprayed the whole engine and it turns out pretty good.
2004 jeep Rubicon, NV3550, NV241 Rock-Trac, windstar cowl intake
sh13lds21 is offline
post #79 of 254 Old 06-10-2011, 12:47 PM Thread Starter
sh13lds21
i was just saying how the stock system is good enough but there more to be had. and i dont agree with everyone that says the stock box isnt restrictive thats IMO.
post #80 of 254 Old 06-10-2011, 12:54 PM
Deacon
Shining Adonis
Deacon's Avatar
How can you say that it both "flows enough air" and then say "its pretty restrictive" in the same breath? You're not FORCING more air into the engine. If all the air it can use is already being provided to it, then how can making more air available change anything?
Deacon is offline
post #81 of 254 Old 06-10-2011, 01:06 PM Thread Starter
sh13lds21
i just feel the stock box is garbage it sucks in air from one side at a 90* bend and then sucks it out on the opposite side. its just a bad design imo
post #82 of 254 Old 06-10-2011, 01:16 PM
Deacon
Shining Adonis
Deacon's Avatar
OK, speculation about design aesthetics aside, does it flow enough air or not? You said it did. Have you changed your mind?
Deacon is offline
post #83 of 254 Old 06-10-2011, 01:27 PM
JeffBowser
You've apparently missed the threads that had real, live, dyno testing links.
post #84 of 254 Old 06-10-2011, 01:28 PM Thread Starter
sh13lds21
enough but not very well.
post #85 of 254 Old 06-10-2011, 01:42 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What do you suggest to improve it?...
Knuckelhead is offline
post #86 of 254 Old 06-10-2011, 02:00 PM
mystangt
I almost fell of my chair laughing when i read:
" Originally Posted by sh13lds21 View Post
These two things cannot be simultaneously true. Please re-evaluate your statements."
The design can DEFINETELY be improved and i am working on something right to do that however I am stuck on finding someone who works with PVC to make me a model to mock-it up...
mystangt is offline
post #87 of 254 Old 06-10-2011, 03:41 PM
Deacon
Shining Adonis
Deacon's Avatar
Quick question: if you get as much air as you can use when breathing through a snorkel while swimming in the ocean, how does it improve anything to breathe through a 3" pipe?
Deacon is offline
post #88 of 254 Old 06-10-2011, 03:55 PM
White99tj
mystangt
The design can DEFINETELY be improved and i am working on something right to do that however I am stuck on finding someone who works with PVC to make me a model to mock-it up...[/quote]
I think if you go to the local pic and pull, you can find an intake tube close to the design your wanting.
The factory tube inside dia is smaller than the windstar. So that is a restrictive point, but opening the intake up won't create great HP dif.
Opening one end is usless unless the other end and everything between is modded to match. Intake engine and exgaust must match for proper HP gains.
I was the first to do the windstar mod and posted pics way back. I only did this mod for under hood clearance for the hiline hood fender mod.
White99tj is offline
post #89 of 254 Old 06-10-2011, 03:59 PM
Deacon
Shining Adonis
Deacon's Avatar
More importantly: can it use any more air? If you dyno it without anything at all bolted to the throttle body, does it consistently and repeatedly show a measurable increase in power greater than the margin of error?
All this talk about giving the engine more air REQUIRES the engine to be starved for air for ANY improvement of ANY attribute of the running engine. If it's already providing all the air the engine can possibly use, then there is absolutely no point to any kind of intake modifications short of forced induction.
Deacon is offline
post #90 of 254 Old 06-23-2011, 01:22 PM
chutta
At one point I had a round chrome/paper filter attached direct to the throttle body, but never had the proper adaptors to get a good secure fitment.
Thoughts on this?
I too want more space under the hood
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
cowl , intake , TJ
Cowl Intake with Windstar air box Hapytruck01 TJ Wrangler Technical Forum 22 04-04-2012 06:51 PM
Cowl Air intake schu TJ Wrangler Technical Forum 2 04-22-2009 08:55 PM
Help with Cowl Intake BDAZCJ5 TJ Wrangler Technical Forum 22 08-14-2005 08:21 AM
Cowl Intake bigblackblur TJ Wrangler Technical Forum 8 02-13-2005 09:37 PM
cowl intake Bucket110 TJ Wrangler Technical Forum 1 10-17-2003 09:00 AM
