Windstar cowl intake - Page 4 - JeepForum.com
 1Likes
post #46 of 254 Old 08-17-2010, 01:00 AM Thread Starter
sh13lds21
a 97 ford windstar
2004 jeep Rubicon, NV3550, NV241 Rock-Trac, windstar cowl intake
sh13lds21 is offline
post #47 of 254 Old 08-17-2010, 07:51 AM
-dirt-
Any concerns for rain entering the intake through the cowl?
-dirt- is offline
post #48 of 254 Old 08-17-2010, 09:32 AM Thread Starter
sh13lds21
i was kinda concerned at first but the rubber piece that goes into the fire wall is up off the bottom about three inches and its not dirrectly under the vent. i havent had any problems so far and i live in northern california and we get quite a bit of rain and there hasnt been any problems. if it does suck up any water theres a drain hole in the intake box so im not to worried about it.
post #49 of 254 Old 08-17-2010, 09:33 AM
-dirt-
Sounds good! Thanks!
-dirt- is offline
post #50 of 254 Old 08-17-2010, 09:42 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you go to start your engine one day and it turns over about 1/6th of a turn and then stops, quit and pull the plugs to pump the water out of the cylinders.
I've seen a few instances of the drain in the bottom of the cowl plugging up with leaves and dirt and then in a hard rain it fills up and runs the rain down into the intake.
I've had to pump them out 3 times now. Oh, and turn the motor over until it pumps dry because the intake holds more water than you think.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #51 of 254 Old 08-17-2010, 10:16 AM Thread Starter
sh13lds21
thanks for the tip but i dont think ill have any problems just dont let the cowl drain get plugged and it will be fine. what kind of cowl intake do you have?
post #52 of 254 Old 08-17-2010, 11:33 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I adapted the stock air box in 00 to fit in mine.
It will never get high enough to flow into the intake.
And then I've done several using the Buick air box.
I am Savvy
post #53 of 254 Old 08-17-2010, 11:42 AM Thread Starter
sh13lds21
thats pretty cool but using the stock box looks like it would be a pita but still does the same job. i was thinking about doing the buick box type but the only reason i would use that is if i was going to do a hummer style intake but i wasnt really up to putting a hole in the cowl cover.
post #54 of 254 Old 11-17-2010, 11:45 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
I looks like you drilled (or cut) a hole in the firewall.
I do have a question. What are your plans for smog testing (if your state has one)?
Group W Bench
CRAWLING 98 is offline
post #55 of 254 Old 11-18-2010, 04:24 AM
Neil F.
Aside from CA, most states do not do any kind of visual verification of parts.
Neil F. is offline
post #56 of 254 Old 11-18-2010, 05:33 AM
biffgnar
biffgnar's Avatar
Why would this change anything for smog testing? All you are changing is where the air intake pulls from. Not seeing why air pulling from cowl would be different for smog than air pulling from behind the headlight. Isn't smog testing really worried more about exhaust side of the engine than intake side?
Romney in 2020!
biffgnar is online now
post #57 of 254 Old 11-18-2010, 05:48 AM
Neil F.
Because the intake tract is an emissions regulated component. K&N and the other big names have gone through the process for CARB certification and being 50 state legal. That's part of the reason they cost so much. The smaller producers's intakes are not CARB legal. However aside from CA other states do not do any sort of visual verifivation under the hood. CA they inspect everything. If emissions regulated parts are not factory or do not have a CARB/EO number tag, they probably will get flagged.
Neil F. is offline
post #58 of 254 Old 11-18-2010, 07:49 AM
biffgnar
biffgnar's Avatar
Is the certification specific to the vehicle? The Buick or Windstar boxes/filters were obviously fine in the vehicles they were in so would they be acceptable in this use? Or is it drawing through the cowl that is going to be flagged? Would have to go back and check but seems like some of the people who have done this are CA based.
Romney in 2020!
post #59 of 254 Old 11-18-2010, 07:51 AM
-dirt-
So does this mean that modifying the intake to become non-CARB compliant is a federal violation, like removing a cat (possibly under the same code)?
If so, a link or citation would be great!
EDIT: Just figured out that the "CA" in CARB stands for Cali. Guess this doesn't apply to the other 49.
-dirt- is offline
post #60 of 254 Old 11-18-2010, 10:17 AM
Neil F.
Yes it does apply because many have adopted CA rules but they have not adopted the practices and procedures. NJ many years ago adopted CA emissions standards but there is no visual inspection other than a quick look under the car for something that "looks' like a cat. The bottom line, if you inspection does not check it, it does not matter.
(I have my own opinion about the "federal violation" topic on this forum and how it is the oly forum where discussion is banned)
From the K&N site
Are K&N performance air intake systems emissions legal in the US?
All intake systems are legal in most states because most states do not have regulations governing them. So this question really has to do with California and other states that have emission control standards. In order for an intake system to be legal in these states, it must receive an Exemption in the form of an EO number from the California Air Resources Board (CARB). To further complicate matters CARB exemption is issued only for specific part numbers used on specific vehicles. That means a part number can be CARB exempt for some vehicle applications and not others. There is no such thing as CARB Pending. A particular part number on a particular vehicle is either exempt or not. The best way for you to determine the status of the part number you are interested in for your vehicle is to look up the intake systems available for your vehicle in our vehicle/part search engine and check for CARB exemption. If you are unsure whether CARB exemption is required for a part to be legal in your state, check with your local or state motor vehicle or emissions agency.
Neil F. is offline
cowl , intake , TJ
Cowl Intake with Windstar air box Hapytruck01 TJ Wrangler Technical Forum 22 04-04-2012 06:51 PM
Cowl Air intake schu TJ Wrangler Technical Forum 2 04-22-2009 08:55 PM
Help with Cowl Intake BDAZCJ5 TJ Wrangler Technical Forum 22 08-14-2005 08:21 AM
Cowl Intake bigblackblur TJ Wrangler Technical Forum 8 02-13-2005 09:37 PM
cowl intake Bucket110 TJ Wrangler Technical Forum 1 10-17-2003 09:00 AM
