windshield removal/installation help
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
hey everyone i was wondering if anyone has any tips on removing the windshield off of an 06 tj. I hit a buzzard this morning doing 60 and my windshield spiderwebbed. I bought a used glass and I want to put it in, but I have a few questions before I start to do it. Am I going to need a new seal? Where can I order one cheap... Does anyone have any good links to a writeup. Today sucked, that money could have went to something better than a piece of glass.
![]() these might sound like dumb questions, but i've tried searching and i haven't gotten any usable information.
06 LJ Bastardized 4.5 33 Mickey T's Jeep note limits mods! |
#2 |
If you financed your vehicle, I'm going to assume that you have full coverage insurance, which should include windshield replacement depending on your amount of coverage. You should talk to your insurance company and see how much the deductible is to have your windshield replaced.
Replacing windshields is shady business, especially if you've never done it before.
2000 Solar Yellow TJ - 4.5" SA Lift - 2" Body Lift (Gross) - 35x12.50xR15 BFG KM's - 8500 lb. Smittybilt XRC8 Check out my build thread! Coming soon: (Green=Done, Red=In Process) HP Dana 44, Ford 9", 4340 35 spline shafts, 101" wheelbase, Aussie Front, Detroit Rear, 4.88 Gears, 38x13.50x16 IROK's |
#3 |
Someone please correct me if I am wrong here.
I had never paid that much attention to the front windshield of my Jeep before, I just went out and looked. I have replaced a couple of other similar types before. Remove all of you old windshield and save the rubber gasket around the edge. Clean the gasket and windsield frame. Mount the gasket around the new piece a glass. You will need a helper at this point. Wrap a heavy string on the inside of the gasket on the inside lip. Have both ends of the string meet at the bottom center of the windshield. Grease the lip of the gasket all the way around and grease the frame as well. Sit the windshield and gasket on the lower edge on the frame from the outside, fitting the bottom of the gasket in place. While you helper holds it in place from the outside, you go to the inside and draw the string ends from the bottom center, out and up around the inside frame. The string will pull the rubber gasket over the lip of the frame. You helper can apply light presure from the outside. If it all works correctly, takes less than 5 mintues. Then clean the excess grease.
jhanna denton county, tx |
#4 |
windshield
thanks for the replies, i would like for my insurance to pay for it, but i don't want my rates to go up. i think i would be able to put it in with the string trick, i've heard of it before. the problem i'm having is devising a way to save my old seal when i remove the glass. i'm pretty sure i can get my hands on some of that auto glass cut out wire, but i'm afraid that i'm going to tear my seal up (the seal from the used glass i bought was torn up this way). the other thing that i've been told was to heat up the seal with a heatgun or blowdryer and push it out, i tried it earlier but i had no luck. there's bound to be someone on this forum who has replaced their glass. this really is a dire problem for me right now, please someone help me.
#5 |
Well, I may can help here also. I happen to be a Firefighter. Cutting windshields out, is also a piece of cake, but it can be a little messy. If you have a good place to work (driveway concrete), cover your inside with a blue tarp. Also cover you hood with a blue tarp. Start with a small hole, punch through your glass near one edge, about a inch or so off, a screwdriver can do this. Then using a "saws-all" or even a jig saw, you can cut around the perimeter of the glass. It does not realy cut but just rips or tears its way through the glass. You will be surprised how fast it wil go, 5-6 minutes and you are done. The main sheet of glass will stay together. Cut from the outside and lay the sheet on your hood when done.
The you can pull the remaining glass and gasket from the frame. Wear gloves and eyewear during the entire process.
#6 |
the wrangler windshield can not be replaced with a string and soapy water!a wrangler windshield is glued in with urethane adhiseve.the outer gasket is a onetime usage it is replaced each time because it is glued on.this windshield install is a pain to remove and install.pay someone who knows what they are doing.i have had two put in mine and mine now has a small chip on passenger side.your insurance will be about 15 dollars a month higher with zero deductible on comp.buy it!jeep windshields are rock magnets.insurance will not go up for a comphrensive claim
#7 |
Tell your insurance company about it. All three of the insurance companies I've had since being 16 couldn't raise my premium every time I hit a deer (I lived in Old Forge, NY, it's common) They can't prove you tried to hit the bird so they can't say it was your fault. If you're still not sure about it just call them up and ask them hypothetically.
#8 |
i said 15 dollars a month,i meant 15 dollars every 6mos.my bad
#9 | |
98 tj sahara re4.5sf,bfg 33 12.50mt d30arb/d44 detroit 456 gears bulletproof bumpers/tomken skids/tor roll cage warn 9000i |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
