Windshield question - JeepForum.com
post #1 of 9 Old 08-21-2006, 09:54 AM Thread Starter
keithert
keithert's Avatar
Windshield question
Can the TJ have the windshield up but have the rollbar sections removed to allow the window to go up and down? Is the window stable enough with the support bars removed for on road driving?
keithert is offline
post #2 of 9 Old 08-21-2006, 10:01 AM
jcd
jcd's Avatar
It would be stable enough for running on the street, though nailing the brakes would cause a pretty nasty flop forward with nothing to retain it and there would be no protection in the event of a roll.
2008 Jeep Sahara Unlimited
Terraflex 4" 35's 5.13
jcd is offline
post #3 of 9 Old 08-21-2006, 10:07 AM
DestructoJr
The Thin Blue Line
DestructoJr's Avatar
Yes! Think about all the aftermarket cages that do away with those bars
Originally Posted by LandRover
3rd graders? Any self-respecting high school teacher could punt them like footballs. :laugh:
Originally Posted by Marneaus
10 because you're awesomely conservative and bash all the liberals. hoorah!
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
DestructoJr is offline
post #4 of 9 Old 08-21-2006, 11:22 AM Thread Starter
keithert
keithert's Avatar
What do you mean nothing to retain it? Aren't there covers on the outside and something on the inside to retain it?
keithert is offline
post #5 of 9 Old 08-21-2006, 11:24 AM
Rusty the Scoob
Rusty the Scoob's Avatar
This is a very, very bad idea. No way would I ride in your jeep with any part of the stock safety systems disabled.
FWIW my ORFab cage ties into the windshield in the stock locations.
2001 TJ Sport 2" coil lift, 31" TrXus, swapped in 3.73s, ORFab cage, Aussie front locker, A to Z Fab rocker skids, JeepMedic Oil Pan Skid, JeepMedic LCA skids, Alloy USA D30 Seals, Warn Diff Skids, Cobra 75wx CB, Jeeperman prototype front bumper, 9.5ti, custom rear bumper, Rokmen frame tie-in kit.
Rusty the Scoob is offline
post #6 of 9 Old 08-21-2006, 11:36 AM
jcd
jcd's Avatar
The bars between the main cage hoop and the windshield are what keeps it from folding. If you undo the two bolts on each of these bars at the windshield frame, the windshield is then free to move forward assuming you have pulled your wipers and the small positioning screw on the sides. Regardless, I agree that it's not a good idea to run without this stuff, but it's just my .02
jcd is offline
post #7 of 9 Old 08-21-2006, 11:41 AM
Hanzo
You could do it. The bolts that go in the side of the frame would be enough to hold it in place while you were driving, but it's risky in the case of an accident. I rolled my Jeep earlier this year only going about 20mph and WITH those bars installed it crushed the driver's side corner of the windshield frame down by about 3 inches. I'm pretty sure that if those bars hadn't been there the entire windshield frame would've given way right into my face.
So, before you do it, keep in mind that on surface streets, doing only 20 mph, those bars probably saved my life.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps." Eleanor Roosevelt, 1945
Hanzo is offline
post #8 of 9 Old 08-21-2006, 02:25 PM Thread Starter
keithert
keithert's Avatar
So was the CJ's setup much sturdier than the Wranglers?
keithert is offline
post #9 of 9 Old 08-21-2006, 02:43 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Guys, there is a good size bolt in both of the windshield hinges that prevents the windshield from laying down even if the side rollbars are removed. That bolt in both hinges must be removed before the windshield can be layed down flat. I can tell how many here have actually folded their windshields down and who are guess.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
Windshield Question wyrmsson TJ Wrangler Technical Forum 30 04-16-2014 05:59 PM
Windshield Question CheapSunglasses YJ Wrangler Technical Forum 1 08-11-2008 11:07 AM
yj windshield question jeepnjohn YJ Wrangler Technical Forum 2 07-01-2008 08:40 PM
Windshield tie down question vertresq YJ Wrangler Technical Forum 11 04-03-2006 07:55 AM
Question about my Windshield... asjdwf TJ Wrangler Technical Forum 19 12-05-2004 08:47 AM
