Quantcast Windshield Mounted light ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Windshield Mounted light ??
Old 05-26-2004, 06:47 AM   #1
Jeep14636
I'm going to put on a pair of windshield mounted lights and want to use KC's. The two I'm looking at are the standard KC and the KC slimlight. Which one is the best choice for mounting on the windshield?
4wheeldrive hardware's catalog shows the slimlights (I think).
Thanks for your input/opinions!
Yeah.....and I'm a Chinese jet pilot
02 Sahara with Dual Tops
Warn x8000i on Tomken winch mount
Sony Head Unit with integrated iPOD, 10 disc changer, Pioneer amp
Cobra CB with Firestik antenna
Raingler nets
RE 4.5 SF with 3.5" springs
AA SYE with a Woody
33 x 12.5 BFG AT's on Cragar Soft 8's
Jeeperman rear bumper and tire carrier
Jeep14636 is offline   Reply With Quote
Old 05-26-2004, 06:48 AM   #2
SirGCal
SirGCal's Avatar
Either one should mount without any issues. The slimlights will for sure offer up no issues.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Old 05-26-2004, 08:40 AM   #3
Jeep14636
SirGCal - Do you have lights here? If so, which ones do you have?
Raingler nets
AA SYE with a Woody
Old 05-26-2004, 08:41 AM   #4
SirGCal
SirGCal's Avatar
PIAA 520 SMR's on Warrior Combo Brackets...
Old 05-26-2004, 09:52 AM   #5
Jeep14636
Thanks for the pic. That PIAA looks great. I'm guessing the KC slim light will have similar dimensions. Maybe I'll go with that one.
Thanks again.
Raingler nets
AA SYE with a Woody
Old 05-26-2004, 09:55 AM   #6
SirGCal
SirGCal's Avatar
Thanks
Yea the slims are more like these. But the standard lights SHOULD fit up there also.. Espically on the more common standard brackets (they have a little more room).
Old 05-26-2004, 10:37 AM   #7
Hal
Both will fit with no problems. I have the full size KC Titanium Daylighters and my brother has the slim sized.
[b]'02 TJ Sport[/b]
Hal is offline   Reply With Quote
Old 05-26-2004, 11:21 AM   #8
DaveFL
Running Slimlights as well on War brackets and they work great.
One thing though I have noticed, depending on year/brackets. Some of the Windshield tabs interfere with the radio Antenna.
I know my War tabs and slim lights work fine, but I ran into a guy running a 03 Rubi like mine with Slimlights on the window not sure tab he used but he had to bend his antenna around the lights.
______________________________
03 Rubicon
Nth 6"LA lift, TT, Stinger/Slider Combo, Superwinch EPI9000, Durango Front & Rear, ORF Tire Carrier, Independent Locker Mod, 15x8 Crager Locks, 35" MT MTZ,Rock Hard Parts trail Cage, AEM Dry Flow, Viking Fastback Top.
DaveFL is offline   Reply With Quote
Old 05-26-2004, 02:35 PM   #9
danofre
yeah, my antenna bouces off and tends to piss me off.
Plus I cant use the passenger side mirror when i take the doors off and need to put on the accesory mirrors. the light is in the way.
danofre is offline   Reply With Quote
Old 05-26-2004, 02:54 PM   #10
SirGCal
SirGCal's Avatar
say... hu?
How is the light in the way for putting on the mirror? And espically, how for one side only?!? (doesn't make sence to me...) My mirror mount isn't anywhere close to the light... I don't see what your having an issue with...
As for the antenna issue, just zip tie it and use a small piece of rubber tubing or silicone to hold it still to the light. It's fine....
Old 05-26-2004, 03:01 PM   #11
danofre
say... hu?
I am aware of how to fix the antenna, it is still annoying though.
As for the mirror. I have quick disconnect mirrors that mount to the side of the windsheild bracket.
http://www.quadratec.com/cgi-bin/sgin0101.exe?T1=13023+01&UREQA=1&UREQB=2&UREQC=3&U REQD=4&FNM=00&UID=2004052615593290
On the passenger side this mirror is meant to be looked at through the windsheild not through the side window. In mounts in the same space that the light resides.
The drivers side mounts as any other mirror would.
Old 05-26-2004, 03:14 PM   #12
SirGCal
SirGCal's Avatar
Through the window... That's funky... I don't think I'd like that anyhow...
Old 05-26-2004, 11:12 PM   #13
Broadway
Hey SirGcal, I wish I had that kind of money to blow on lights, but my wife says we need to buy a house!!!
2000 Black TJ Sport, FF14 bolt disk brakes Detroit and 5.13s, HP D60 ARB and 5.13s, TF727/Atlas 4.3, stretched 104" on 39" IROKS
Broadway is offline   Reply With Quote
Old 05-27-2004, 07:40 AM   #14
SirGCal
SirGCal's Avatar
That's what mine want's too (as well as me) but we still rent. (Houses in Austin are SO REDICULIOUSLY priced that I'm suprised anyone can afford one...)
But the PIAA 520 SMR's weren't too bad... I paid I think only about $200/pair... Not horrible as far as lighting goes... (I could easily go higher... Well, I could easily FIND more expensive anyhow... ) But yea you can get some other models much cheaper... I think the KC's might even be half that...
Glock Forum
