Windshield Leaking Inside upper right side - JeepForum.com
post #1 of 2 Old 11-13-2012, 01:36 PM Thread Starter
Okiiashi
Okiiashi's Avatar
Hey guys/gals. I got this annoying leak that showed up the past few weeks with the heavy rain. It looks like it was coming from across the gasket between the mirror and passenger pillar.
I bought some of the windshield sealant and went across the outside rubber between the frame and glass (upper part only). I also jabbed the tube from the inside where I thought the leak was coming from and gave a few squirts.
Two days later it rained again..... now in the leak is coming more on my side from above the rear view mirror!
Now I want to rip that entire black rubber part outside and shoot it with silicone then place that rubber back around the glass. Am I able to do that??
Also searching I read about the heater core part, but I don't think the water would run UP the windshield and drip from the top while the jeep is parked.
Thanks
|¯¯l,[___],
l---L--OlllllllO¬
()_) ()_)---)_)RED JEEP #446
“Even if you’re on the right track, you’ll get run over if you just sit there” - Will Rogers
Okiiashi is offline
post #2 of 2 Old 11-13-2012, 07:14 PM
mukluk
Silicone is only going to be a bandaid fix, it'll eventually leak again and worse, it may end up promoting rust in your windshield frame. The best solution would be to replace the windshield seal and bond it in to the frame with urethane adhesive.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
leak , rain , windshield
