Windhshield Light Bar Wire Question w/ (PIC) - JeepForum.com
post #1 of 11 Old 07-19-2010, 10:56 PM Thread Starter
inglisleslie
I am getting the 4 light tab windshield guard/light bar and monstalineing it! I am running my 4 KC Lights and want them all controlled by a second OEM fog light switch. Can I piggy back all the daystars up in the light bar? Use lower gauge wire? Do I need a relay or can I wire directly to the switch(what size fuse) (I want all 4 to turn on at once, nothing fancy)? Any body have what thecolors are for the back of the OEM fog ligh?
inglisleslie is offline
post #2 of 11 Old 07-19-2010, 11:14 PM
TheDragonfly
What wattage KCs?
TheDragonfly is offline
post #3 of 11 Old 07-19-2010, 11:55 PM Thread Starter
inglisleslie
Originally Posted by TheDragonfly View Post
What wattage KCs?
using 4, 100w lights
KC HiLiTES 238 - KC HiLiTES 100 Watt Daylighter Pair Pack System - Quadratec
post #4 of 11 Old 07-20-2010, 12:03 AM Thread Starter
inglisleslie
here is stu's write up on the stock fog light switch and what the 4 wires are:
TJ Fog Light Switch
post #5 of 11 Old 07-20-2010, 12:14 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
no you should NOT wire them directly to the switch... well you can ONCE and you'll let all the smoke out of it.
you should run 1 appropriate amp rated relay for each pair of lights [ so 2 relays] you can have the stock switch turn on both relays at the same time. make sure you run the correct gauge wiring and fuse each relay. theres mannnnny write ups on it or for quick reference go to the tech page on the website below.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #6 of 11 Old 07-20-2010, 12:36 AM Thread Starter
inglisleslie
post #7 of 11 Old 07-20-2010, 12:37 AM Thread Starter
inglisleslie
what light powers the fog light switch, is it the t4(type B)?
post #8 of 11 Old 07-20-2010, 01:24 AM
sixmanz
Im gonna see if I can find this light bar on the world wide web but if I cant find it can you tell me what brand it is. sorry I cant help with the wiring issue. I just went the simple route and put in some aftermarket switches.
sixmanz is offline
post #9 of 11 Old 07-20-2010, 01:51 AM
SFT2
One 40 amp relay will handle 4 100w lights (roughly 30 amps total), but it's not the best plan. When I put in my 100w lights a few weeks ago I put two on a 40 amp relay with a 20 amp fuse and 12 ga. wire, 18 ga. from the relay to a factory fog light switch, with a factory pigtail, spliced into the existing wiring to the original fog light switch. Works perfectly.
Mine- 2k TJ, RC 2.5 lift, .75 spacers, Soft 8s, 33" KM2s, winch, lights, and so on
Hers- 06 WK, bone stock until she leaves it and the credit card with me for an unsupervised weekend
You're the retarded offspring of five monkeys having butt sex with a fish-squirrel.
SFT2 is offline
post #10 of 11 Old 07-20-2010, 03:02 AM
theGiantPanda
Swap This...
if your adding the fog light switch, you can decide what source powers it, be it constant battery or ignition switched for example. the fog light internal light or 'illumination wire' should be spliced/tapped into the factory dash lighting circuit behind the dash. basically jumped off from another exisiting switch etc.
the new shop...
shop email....
adding more daily
post #11 of 11 Old 07-20-2010, 09:46 AM Thread Starter
inglisleslie
this is a small company but cool stuff Windshield Guard - Custom - $80.00 : Zen Cart!, The Art of E-commerce
kc , light , light bar , wiring , help , advice , relay
Windhshield Wipers upright! oaklane JK Wrangler Technical Forum 10 01-10-2009 06:07 AM
How to wire my dome light? Rev6 YJ Wrangler Technical Forum 3 03-11-2008 07:42 AM
Windhshield wipers stopped working jeepman44 TJ Wrangler Technical Forum 5 01-02-2008 01:53 PM
Reverse Light Wire nckm126 TJ Wrangler Technical Forum 0 04-12-2007 09:05 AM
seatbelt light/wire question ncjeepinyj YJ Wrangler Technical Forum 6 11-07-2004 06:58 PM
