Winch Wiring - Page 2 - JeepForum.com
post #16 of 24 Old 06-24-2010, 04:38 PM Thread Starter
skouklis
Line Pull/Motor Amps 12V
0/33
2,000/110
4,000/200
6,000/230
8,000/260
9,000/350
so according to this an 8000 pound pull takes 260 amp draw is this continues or is this momentary
skouklis is offline
post #17 of 24 Old 06-24-2010, 05:04 PM
biffgnar
biffgnar's Avatar
0/33
2,000/110
4,000/200
6,000/230
8,000/260
9,000/350
On a tough pull where I am good and stuck or where I need to get up a decent size hill I have a feeling it is more than momentary that's why I have been looking at switches rated to 300-350A continuous. Remember this table is my winch (Superwinch EPSi9.). If you have a different winch you need to check what it draws.
Romney in 2020!
biffgnar is online now
post #18 of 24 Old 06-24-2010, 05:09 PM
BlueFlame
BlueFlame's Avatar
Those amp draws are continuous.
BlueFlame is offline
post #19 of 24 Old 06-24-2010, 07:18 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Is any one running a fuse on the winch 12 volt battery connection?
No. Are you running a fuse on the feed wire for your starter motor?...
Knuckelhead is offline
post #20 of 24 Old 06-24-2010, 07:21 PM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
The one I have is a fuse that is in a holder that looks similar to this. If I had to buy a new one - I would probably try this circuit breaker. I have never had the 150AMP fuse blow on my harbor freight 8000 winch. I would imagine a faster WARN might draw more...
Circuit Breaker 100 150 200 amp - All for the same price
EDIT - snapped a pic for you - you can see my plow and winch feed wires coming off the fuse.
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #21 of 24 Old 06-24-2010, 07:34 PM
biffgnar
biffgnar's Avatar
Good to hear. BTW, based on a quick search looks like draw on the HF8000 is:
0/45
2000/105
4000/160
6000/230
8000/300
Romney in 2020!
post #22 of 24 Old 06-24-2010, 07:52 PM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
0/45
2000/105
4000/160
6000/230
8000/300
Wierd - I KNOW I pushed the old winch to near the limit - I pulled down trees, pulled my boat lift out of the mud in the lake to the point where I had to strap the jeep to a tree to keep it from pulling it in the lake, let alone the trails where I winched myself up some steep inclines - and the draw would have been even more huge when the motor was starting to fail and come apart....
When I use my plow, if I am using the plow for more then a few seconds at a time, the volt gauge drops and the check gauges light comes on. That kind of a draw has to be pretty huge....
Todd Thorson
My Band! ->
post #23 of 24 Old 06-24-2010, 08:30 PM
Stu Olson
Stu Olson's Avatar
A 500 amp 12 volt fuse.....perfect for a Jeep and a winch.
Looks like this when installed.....Robert Yates has this on his TJ.
The write-up where the fuse and associated components are all covered.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #24 of 24 Old 06-25-2010, 08:40 AM Thread Starter
skouklis
I did not know they even had a 500 amp fuse grate info
skouklis is offline
winch , fuse
TJ in-cab winch wiring? BUSAFREAK TJ Wrangler Technical Forum 8 08-11-2010 08:03 PM
Help wiring a winch drdfblackm TJ Wrangler Technical Forum 9 01-03-2010 08:59 AM
winch wiring help kllrbee TJ Wrangler Technical Forum 6 04-07-2009 08:03 PM
Winch wiring GPTJ TJ Wrangler Technical Forum 4 11-21-2004 08:09 PM
winch wiring MugZy_YJ_94 YJ Wrangler Technical Forum 8 01-30-2004 01:18 PM
