Winch Wiring - JeepForum.com
post #1 of 24 Old 06-24-2010, 01:22 PM Thread Starter
skouklis
Winch Wiring
Is any one running a fuse on the winch 12 volt battery connection?
skouklis is offline
post #2 of 24 Old 06-24-2010, 01:23 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
I'm not??Direct to battery!
GOLENJEEPTJ is offline
post #3 of 24 Old 06-24-2010, 01:58 PM
jtgreen76
directly to the battery. i just use the on/off switch that is on my winch to shut it off havent had any problems.
prepare for the worst and then prepare again
jtgreen76 is offline
post #4 of 24 Old 06-24-2010, 02:26 PM Thread Starter
skouklis
On and off switch? The 12 volt wire still has power to the winch if the remote is unplugged or off.
skouklis is offline
post #5 of 24 Old 06-24-2010, 02:40 PM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
I have a 150AMP fuse that comes off my battery that actually came with my snowplow setup. I hooked my winch cable to that fuse, right with the plow wire (since I dont use both at the same time) - never any issues with a HF 8000# winch. Even when the first winch died (motor crumbled, magnet pieces all over after 4 years of heavy use) it didnt take out the fuse.
I would do it - if a cable rubs through and welds itself to the body somewhere - it will take out the battery in short order....
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #6 of 24 Old 06-24-2010, 02:42 PM
mschviuz
Where is the best place to get a fuse that size. I think it would be a good idea too.
mschviuz is offline
post #7 of 24 Old 06-24-2010, 02:45 PM
wannahdawg
my guess would be a stereo shop or radio shack?
Just Empty Every Pocket then Just Experience Extreme Performance
wannahdawg is offline
post #8 of 24 Old 06-24-2010, 02:46 PM
gtstricky
None here. No fuse on the wire going to my alternator either
Must reads for new TJ Owners:
gtstricky is offline
post #9 of 24 Old 06-24-2010, 02:50 PM
mschviuz
I don't know why I didn't think of that. You see those fuse blocks on stereo systems all the time. The idea of the + cable getting nicked and shorting out the battery would be bad bad bad
I don't know if 150 would be a big enough fuse though.
mschviuz is offline
post #10 of 24 Old 06-24-2010, 02:56 PM Thread Starter
skouklis
especially since the winch is in the front of the jeep, a jeep accident would not be good.
skouklis is offline
post #11 of 24 Old 06-24-2010, 03:01 PM
biffgnar
biffgnar's Avatar
Currently mine is wired straight to battery but was thinking about adding a marine battery disconnect switch in line under the hood. If there is going to be a rub and short seems likely it would likely be going through/under the grill. Battery disconnect switch before that allows for cutting off power to that point. Just have to make sure what ever you add can handle the not insignificant draw of a hard pull.
biffgnar is offline
post #12 of 24 Old 06-24-2010, 03:05 PM Thread Starter
skouklis
ya something like that what should it be rated for
Amazon.com: NEW BATTERY KILL SAFETY SHUT OFF DISCONNECT SWITCH: Automotive
skouklis is offline
post #13 of 24 Old 06-24-2010, 03:08 PM Thread Starter
skouklis
So what should a fuse or a switch be rated for?
skouklis is offline
post #14 of 24 Old 06-24-2010, 03:11 PM
biffgnar
biffgnar's Avatar
I guess it depends what "continuous" means in electrical speak. Not really my area of expertise. Chart for my winch looks like draws in the 200-300 amps range are what I need to plan for:
Line Pull/Motor Amps 12V
0/33
2,000/110
4,000/200
6,000/230
8,000/260
9,000/350
And IIRC some other models of winches looked like draws in the 300-400 amp range were not out of the question.
biffgnar is offline
post #15 of 24 Old 06-24-2010, 03:18 PM
biffgnar
biffgnar's Avatar
I was thinking about something like this: BLUE SEA SYSTEMSSwitch at West Marine
biffgnar is offline
winch , fuse
TJ in-cab winch wiring? BUSAFREAK TJ Wrangler Technical Forum 8 08-11-2010 08:03 PM
Help wiring a winch drdfblackm TJ Wrangler Technical Forum 9 01-03-2010 08:59 AM
winch wiring help kllrbee TJ Wrangler Technical Forum 6 04-07-2009 08:03 PM
Winch wiring GPTJ TJ Wrangler Technical Forum 4 11-21-2004 08:09 PM
winch wiring MugZy_YJ_94 YJ Wrangler Technical Forum 8 01-30-2004 01:18 PM
