winch weight on rubicon - JeepForum.com
post #1 of 9 Old 08-27-2007, 02:18 PM Thread Starter
SilverRubi06
hi again guys, i have seen a few threads about people putting winches on and then noticing a sag in the front end, but in all the threads i have seen, those people are running lifts on their jeeps and usually aftermarket bumpers. can anybody tell me of there is much sag by adding about 120 pounds (89 for the winch and i'm guessing 20-30 for the mount plate) with a factory bumper on a factory 06 rubicon suspension? will the lifetime of the front end be noticably shortened? also, does anybody know if i will still be ale to use my factory tow hooks after intalling the mounting plate? (looking to put on a warn 9.5ti by the way if that helps) and finally, i have seen mentions on the 9.5ti blocking too much of the grill (airflow issue) but have not seen anything definitive about it. planning on getting a winch tonight or first thing in the morning so any help would be greatly appreciated! thanks in advance!
SilverRubi06 is offline
post #2 of 9 Old 08-27-2007, 02:26 PM
Crashnburn80
Crashnburn80's Avatar
With stock suspension my Warn M8000 + plate I saw a front sag for about 0.5"-1".
Yes, the factory tow hooks can still be used, but you need to switch the right and left hook, so that the left hook is on the right side. This is because the hook is offset, and if you leave them in the stock configuration it will contact the plate.
If you switch the hooks though, the hooks interfere with the fogs, so you need to move the fogs outward. If you have removed your front bumper floaties (please say you have) then the floatie mounting holes work perfect for the fogs. See the pic link in my sig for what it looks like.
I do not think a 9.5ti will cause any airflow issues, many people run them.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #3 of 9 Old 08-27-2007, 06:10 PM Thread Starter
SilverRubi06
thanks! would the extra weight cause longevity issues for the springs or shocks? cause them to weaken a lot sooner? and yes, i removed the plastic floaties almost my first day. they dont look right...
post #4 of 9 Old 08-27-2007, 06:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Just install a 3/4" or 1" polyurethane spacer on top of the front springs to compensate for the weight of the winch or winch plus bumper.
Getting
Jerry Bransford is offline
post #5 of 9 Old 08-27-2007, 07:17 PM Thread Starter
SilverRubi06
sounds like a plan, if the sag is noticable enough and if it bothers me enough... thanks
post #6 of 9 Old 08-27-2007, 08:35 PM
claytonandson
claytonandson's Avatar
i just use a reciever mount for winch.goes right into the reciever and safely back away when ot in use.
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline
post #7 of 9 Old 08-27-2007, 08:39 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I used 1" coil spacer bought off eBay for my winch and winch plate weighing roughly 115#. Looks like I could use 1.5" or 2" spacer after all the sagging.
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #8 of 9 Old 08-28-2007, 02:44 AM
dawnskaybug
dawnskaybug's Avatar
I bought my coil spacer off Ebay.. Mine split in half the 2nd time on the trails..
05 LJ
RE 4.5 SA 1inch BL
Aussie front Detroit rear 4.88s
1200 series Tractor tires (37x10)
Warn winch stinger
Lotsa trail damage
dawnskaybug is offline
post #9 of 9 Old 08-28-2007, 07:05 PM
Gunnison
Gunnison's Avatar
2008 WK
My 2006 LJ Rubi has the Warn 9.5ti with the Mopar Jeep winch bumper. To level it out I installed 2" spring spacers. I still need about another 3/4" to level it. Doing it again I would go with the adjustable spacers like the JKS Acos which allows you to dial in the exact height you need to level it to your taste.
02 GC Overland, 4" RCLA, 4.5 Clayton Springs w 3/4spacers in front, Bilstiens, JKS Tracbar, Addco rear sway bar, Proto Fab Hi Clearance bumper, Smitty built 8,000 w/Syn
Previous Jeeps: 57 Willys, 74 J-10, 76 J-20, 80 CJ7, 91 XJ, 97 ZJ, 97 TJ, 00 TJ, 06 LJ Rubicon, 2010 JK Rubicon 4dr.
Gunnison is offline
avg bumper/winch weight? rballman JK Wrangler Technical Forum 2 09-15-2009 02:35 PM
winch weight bigV TJ Wrangler Technical Forum 20 11-07-2006 09:00 PM
How well does the TJ handle winch weight? mudmonkey2400 TJ Wrangler Technical Forum 10 03-29-2006 01:15 PM
New Winch weight issues.... colbyB25 TJ Wrangler Technical Forum 2 12-26-2005 02:23 PM
Winch weight? jeepfury YJ Wrangler Technical Forum 5 12-07-2005 02:22 AM
