winch weight bad ? - JeepForum.com
post #1 of 48 Old 11-22-2010, 02:19 PM Thread Starter
Bludnguts
winch weight bad ?
So i have a 2005 jeep TJ and i have put a 2 1/2" lift and 33's on, and i am worry some when i take it out cuz i dont wanna get stuck out in the boonies. i currently have a smittybilt front bumper on it and it has a slight rake on it, but i wanna put a winch on it but i looked it up and it weighs 94lbs and i wanted to know how much more it would lower my jeep. i dont want a huge rake on my jeep a slight rake is fine with me though. thanks ..
Bludnguts is offline
post #2 of 48 Old 11-22-2010, 02:25 PM
MikeyJ
All jeeps are different, find something or someone near 100pounds and have them stand on the front bumper.
MikeyJ is offline
post #3 of 48 Old 11-22-2010, 02:29 PM
Drew4
Win. /thread.
2003 Jeep Wrangler Sahara. Stock, for now.
WTB: lift kit for 2003 TJ. Prefer suspension lift, student budget. Located in Ontario.
Drew4 is offline
post #4 of 48 Old 11-22-2010, 02:40 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Most people add spacers after mounting the winch if needed, to level out.
GOLENJEEPTJ is offline
post #5 of 48 Old 11-22-2010, 03:11 PM
OutermostJeep
2009 JK Wrangler
Yup. Added 3/4" spacers to mine after installing the winch, and all is well.
OutermostJeep is offline
post #6 of 48 Old 11-22-2010, 03:22 PM
blubaru2002
Throw the winch on there and start parking facing up hill.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #7 of 48 Old 11-22-2010, 03:30 PM
MO2500
This.
Also, you could run synthetic winch line. Safer and lighter than steel cable which would help reduce the overall weight your adding to the front bumper
Instagram: @omsmike
MO2500 is offline
post #8 of 48 Old 11-22-2010, 03:40 PM
Darkmoon
Originally Posted by mo2500 View Post
also, you could run synthetic winch line. Safer and lighter than steel cable which would help reduce the overall weight your adding to the front bumper
x2
Is It So Wrong To Be In Love With Your Jeep?
1999 TJ "Diablo Rojo"
RC 4" Suspension Lift, JKS 1.25" Body Lift, G2 Rear Dana 44 with4.88 gears and Auburn ECTED Max Locker and Disc Brake Conversion, Front Auburn ECTED MAX Locker, MORE 1" Motor Mount Lift, Off Road Only U-Turn Crossover Steering, Pro Comp Front Track Bar, Terraflex Adjustable Rear Upper Control Arms, Blumenthals Custom Rear Driveshaft, JKS Extended Brake Lines, JKS Bar Pin Eliminator - Front & Rear, JKS Shock Conversion, MORE Steering Brace, TeraFlex Sway Bar System, ARB Snorkel, Purple Cranium Differential Spyder Skid, 35x12.50x15 BF Goodrich Mud Terrain KM2's on 15 X 8 Black Pro Comp Street Beads Wheels, Rancho Shocks and Steering Stabilizer, Smittybilt Front & Rear Bumpers, Smittybilt XRC 8 Comp Winch, Skid Row Offroad Radiator Guard, Skid Row Lower Control Arm Skids, Warn Steering Box Skid, Poison Spyder Custom Crusher Corners, Front Fenders & Ricochet Rockers,12 Volt Guy Incab Winch Control, and much more...
Darkmoon is offline
post #9 of 48 Old 11-22-2010, 03:45 PM
GOLENJEEPTJ
Yep... pros & cons to synthetic.I personally like it but, I will wait before the several hundred dollar replacement line on my Warn. It is still great after many years and situations.
post #10 of 48 Old 11-22-2010, 06:04 PM
2005X
for me after 4 years of running 100ft of steel cable with several kinks, and lugging around all the extra weight i see a synthetic cable in my near future.
2005X is offline
post #11 of 48 Old 11-22-2010, 07:41 PM
Gary2
I think I read switching to synthetic on an M8000 would take about 30-35lbs off of it which makes a big difference on the front bumper of a Jeep
Gary2 is offline
post #12 of 48 Old 11-22-2010, 07:48 PM
flatlander757
Makes a big difference to your wallet too
It's good stuff, but no reason to change if your steel cable is still in good shape and you PROPERLY MAINTAIN IT and use it SAFELY
Just get some front spring spacers to fix your leveling issues
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #13 of 48 Old 11-22-2010, 08:33 PM
Gary2
I just didn't care for the way the jeep felt with the added weight on the nose between the plate and the winch it adds up which is why the front gets lower naturally. I added a spacer so it looked better but thats all a spacer does in that case it just makes it looks better when whats needed is stronger springs.
Gary2 is offline
post #14 of 48 Old 11-22-2010, 08:39 PM
subtlez28
I deleted my winch for the same reason. My Superwinch with plate weighed 120 pounds!
Not to hyjack, but why don't more people run a front 2" receiver, so the winch could be carried inside, then slid into the front or rear receiver depending on situation? I think that is my plan unless I missed something.
And synthetic line sounds like a worthwhile investment to me. I cannot shake my road racing, every pound counts mentality.
01 XJ Cherokee 4.0/M5
03 TJ Rubicon-4.0/M5 33s,Savvy TT SOLD
97 TJ-4.0/M5 31s SOLD
subtlez28 is offline
post #15 of 48 Old 11-22-2010, 09:04 PM
BYuen
BYuen's Avatar
Also depends on the springs you have. I run RE springs with a high spring rate. After I added all the armor, bumpers, winch, and whatnot, I didn't notice too much of a difference.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
winch weight
avg bumper/winch weight? rballman JK Wrangler Technical Forum 2 09-15-2009 01:35 PM
winch weight on rubicon SilverRubi06 TJ Wrangler Technical Forum 8 08-28-2007 06:05 PM
winch weight bigV TJ Wrangler Technical Forum 20 11-07-2006 08:00 PM
New Winch weight issues.... colbyB25 TJ Wrangler Technical Forum 2 12-26-2005 01:23 PM
Winch weight? jeepfury YJ Wrangler Technical Forum 5 12-07-2005 01:22 AM
