winch weight - JeepForum.com
post #1 of 21 Old 11-07-2006, 12:15 AM Thread Starter
bigV
bigV's Avatar
winch weight
I'm looking at adding a winch. Do I need to beef-up the front suspension for the extra weight? If I get the synthetic rope instead of the wire will it be ok?
bigV is offline
post #2 of 21 Old 11-07-2006, 01:15 AM
Millertime06
Im sure you do and these guys will be able to answer that. But I just know from my work (UPS). Those things come through, usually the warn 9.5, and it weighs like 97 lbs, pretty damn heavy.
03 Freedom X
33 Pro comp muds on pro comp alloys, RE BB, 1" PA BL, Rancho SS, W/S Daylighters, Olympic grille guard, Rock crawler rear bumper with tire swing, KC Back up Flood lights, some sound stuff - SOLD =(
Millertime06 is offline
post #3 of 21 Old 11-07-2006, 02:16 AM
Jerry All-Bran
Jerry All-Bran's Avatar
The 9.5ti is pretty heavy.
However, a sagging issue can be rectified through a variety of means.
From what i've heard, a lot people use 1" coil spacers (or 2, however much is needed).
You can also do this:
http://www.4x4xplor.com/airlift.html
What I did w/ my sagging front due to my 9.5ti was replace my 98SE 2.5L w/ an 05RubiLJ 4.0L. Stiffest coils you can get from DC today for the TJ's. I actually not only ended up getting rid of the sag, but recovering an 1" of height
Jerry All-Bran is offline
post #4 of 21 Old 11-07-2006, 06:31 AM
ChuckDee
100' of 5/16 wire rope going to be around 18 pounds I believe. 100' of 3/8 synthetic (for me) was around 5.5.
Previously owned: 2001 TJ Sport
ChuckDee is offline
post #5 of 21 Old 11-07-2006, 07:18 AM Thread Starter
bigV
bigV's Avatar
I already have a 1.75" coil spacer lift, so it seems like the stiffer rubicon springs would be the easiest thing to do.
bigV is offline
post #6 of 21 Old 11-07-2006, 07:24 AM
nierace
nierace's Avatar
2003 WJ
Browse the used section for them...they're pretty easy to come by and you'll save from $ as appose to buying from DCX directly....
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #7 of 21 Old 11-07-2006, 07:32 AM
CNY
Caught ridin' dirty
What winch are you looking at getting?
CNY is offline
post #8 of 21 Old 11-07-2006, 10:31 AM
milehighclub
milehighclub's Avatar
I don't know about the total weight of my winch but, when i switched for a synth rope/ hawse fairlead, my Jeep lost 25 pounds and recovered 1/2" of front clearance
(100' - 5/16" synth vs 100' - 3/8" steel)
milehighclub is offline
post #9 of 21 Old 11-07-2006, 10:40 AM
grundrc
grundrc's Avatar
Originally Posted by Akula47
I can't say I would ever recommend this solution. I've had them and had nothing but leaking problems from either pulling the line loose or somehow puncturing the bag. Great idea in theory. Not too practical for a Jeep.
97 4.0 TJ, 700R4 auto, 4" Teraflex suspension w/RE long arms, 1 3/4" CS, 2" BL, 4.56 gears, ARBs F/R, 35/12.5x15 GR ATs, 10x15 Eagle rims, Warn 9500i winch, Bulletproof bumpers/tire carrier, Sun Perf. rocker guards
05 5.7 WK Ltd.
07 JK Unlimited Rubicon
grundrc is offline
post #10 of 21 Old 11-07-2006, 10:42 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The simplest/cheapest thing is just to install a 3/4" polyurethane coil spacer on top of the front springs. Works fine, lasts a long time.
Getting
Jerry Bransford is online now
post #11 of 21 Old 11-07-2006, 11:51 AM
Rusty the Scoob
Rusty the Scoob's Avatar
This is what I did. Levelled it out nicely.
2001 TJ Sport 2" coil lift, 31" TrXus, swapped in 3.73s, ORFab cage, Aussie front locker, A to Z Fab rocker skids, JeepMedic Oil Pan Skid, JeepMedic LCA skids, Alloy USA D30 Seals, Warn Diff Skids, Cobra 75wx CB, Jeeperman prototype front bumper, 9.5ti, custom rear bumper, Rokmen frame tie-in kit.
Rusty the Scoob is offline
post #12 of 21 Old 11-07-2006, 02:21 PM
anebrich
You may want to consider the Warn 9.0rc, it's only 54lbs versus the 9.5ti's 89lbs!
anebrich is offline
post #13 of 21 Old 11-07-2006, 02:52 PM Thread Starter
bigV
bigV's Avatar
I already have a 1.75" coil spacer lift, so would the rubicon coils be the way to go for me?
bigV is offline
post #14 of 21 Old 11-07-2006, 02:59 PM Thread Starter
bigV
bigV's Avatar
I'm still looking. I wish I could get the new warn winch/compressor combo, but that's a little steep for me. Probably a Mile Marker. A friend of mine has a hydraulic one and he's never had any complaints.
bigV is offline
post #15 of 21 Old 11-07-2006, 03:02 PM
Rusty the Scoob
Hydraulics are slooooooooow and the engine has to be running in order to winch yourself out of anything.
There's a reason not too many people run them... but those that do seem to like them.
avg bumper/winch weight? rballman JK Wrangler Technical Forum 2 09-15-2009 02:35 PM
winch weight on rubicon SilverRubi06 TJ Wrangler Technical Forum 8 08-28-2007 07:05 PM
How well does the TJ handle winch weight? mudmonkey2400 TJ Wrangler Technical Forum 10 03-29-2006 01:15 PM
New Winch weight issues.... colbyB25 TJ Wrangler Technical Forum 2 12-26-2005 02:23 PM
Winch weight? jeepfury YJ Wrangler Technical Forum 5 12-07-2005 02:22 AM
