Winch-Pictures of How You Ran the Wires - JeepForum.com
post #1 of 13 Old 07-03-2010, 11:27 AM Thread Starter
explorerlyon
I have seen some pictures of wires running from the winch THROUGH the grill and comments of the wires rubbing on the grill. I have read posts of the wires running under the grill along the sway bar. Anyone have pictues of how they ran the wires under the grill instead of through the grill? Pictures of how you ran them through the engine compartment.
05 Rubicon Unlimited, Automatic
explorerlyon is offline
post #2 of 13 Old 07-03-2010, 12:43 PM
wranglerWestLA
I just mounted my Winch yesterday.
As soon as I will reach 25 posts, I will be able to post pictures.
I think I did a good job with the wiring.
I will take pics today and post them later.
wranglerWestLA is offline
post #3 of 13 Old 07-03-2010, 12:43 PM
jdub36
I ran mine through the grill around the radiator and next to the air box up to the battery. I ran the wires in wire loom and wrapped them in electrical tape to keep them from getting cut. So far seems to work well for me.
jw
jdub36 is offline
post #4 of 13 Old 07-03-2010, 06:42 PM
BlueFlame
BlueFlame's Avatar
Electrical tape won't save them, only adds a few extra hours of chafe prevention if that.
Get some hard plastic covering that's designed for wire protection, or at least use a piece of garden hose or something heavier than tape...
BlueFlame is offline
post #5 of 13 Old 07-03-2010, 07:36 PM
TeeJay00
Does this help??? I then connected the wires to the side terminals on the battery
I just took those pictures and it's pretty dark right now here... If you want more clear ones I can take them tomorrow at day time.
TeeJay00 is offline
post #6 of 13 Old 07-03-2010, 07:40 PM
robncar
robncar's Avatar
Yep, we ran through the grill but used split loom to protect the wires. If those wires short, it's not pretty...
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #7 of 13 Old 07-03-2010, 07:53 PM
wushaw
Rockin jeep
wushaw's Avatar
I ran mine under in seperate looms, up inner fender to a 600amp cutoff switch mounted in ft. of airbox then on to the battery compartment.
wushaw is offline
post #8 of 13 Old 07-03-2010, 08:15 PM
Mousejockey
The side terminals aren't connected as well as the top terminals. Optima will not warranty a battery if a winch was connected to the side terminals.
Mousejockey is offline
post #9 of 13 Old 07-03-2010, 08:19 PM
TeeJay00
Well when you buy an optima used with no warranty it doesn't matter i guess
But will this effect my winch operation or anything? I have had it this way for almost two years now!
TeeJay00 is offline
post #10 of 13 Old 07-03-2010, 09:28 PM
drummerchukb1
i have the 2.5l so it may be different, but i ran mine through the grille, farthest to the passenger side, through a hole created by the rad, and the grill/ fender. i used heat shrink tubing on it where the wires touch the rad frame, to help protect them. from there, straight to the battery. i suppose i might be able to get pics tomarow if you still need them
drummerchukb1 is offline
post #11 of 13 Old 07-03-2010, 09:31 PM
drummerchukb1
sorry, after re- reading the original question, my responce is usless
post #12 of 13 Old 07-04-2010, 09:57 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Maybe, maybe not. When doing a hard pull, the connections inside the battery could melt...
Knuckelhead is offline
post #13 of 13 Old 07-04-2010, 09:57 AM
jdub36
you are right that is why i ran them in wire loom, i just used the tape to keep the wire loom in place.
jw
jdub36 is offline
winch , winch install , winch wiring , winch wire routing
R/C winch plate & 8500lb Super winch on factory bumper. fernjack JK Wrangler Technical Forum 17 11-23-2010 11:12 AM
HF winch plate Trimming to fit PIctures Madmanmiller802 TJ Wrangler Technical Forum 2 06-11-2010 01:06 PM
Pics of new MOPAR winch bumper, the one w/fog light cutouts & Hyd winch nycrd JK Wrangler Technical Forum 25 12-11-2009 06:33 AM
How do you route your winch power cables? Pictures? loudog3114 TJ Wrangler Technical Forum 8 08-19-2005 09:35 PM
Finally Pictures of My Jeep With Winch Brassmonkey TJ Wrangler Technical Forum 14 08-09-2004 11:09 AM
