Will an XJ steering box fit a TJ? - JeepForum.com
post #1 of 10 Old 07-12-2010, 05:13 PM Thread Starter
dodgetk81
Can an XJ steering box be installed on a TJ? I am going to a U pull it yard and need a steering box for an 02 TJ. I dont know if there will be any Durango's there or not. I do know there are a bunch of Cash for clunker XJs. I tried a search but XJ and TJ are too short.
Thanks
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
post #2 of 10 Old 07-12-2010, 05:16 PM
LKrux
hmm u know im pretty sure they should fit. id take a close look at mine and take pictures and measurements and see if they match when u compare to the ones at the yard.
i would bet u can swap them, i doubt the factory changed that. i mean they used almost the same drive train.
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline
post #3 of 10 Old 07-12-2010, 05:17 PM
wrangler1988
check autozones website for both vehicles and see if the same part number comes up.
wrangler1988 is offline
post #4 of 10 Old 07-12-2010, 08:23 PM
BliZZard911
Yes an XJ steering box will fit on a TJ. If it's a 3 bolt, it will fit.
2000 Jeep TJ Wrangler - 4.0L, 5 speed standard - BONE STOCK FOR NOW
BliZZard911 is offline
post #5 of 10 Old 07-12-2010, 08:53 PM
jeeptinker78
I swapped an XJ box into my TJ this past weekend to replace my leaking gear box. Direct bolt-in. Same part numbers.
'97 TJ: DD and Weekend Warrior
'58 CJ-3B: Dauntless V6, NP-435, D-18, D-30 Front and D-44 Rear (5.38:1), Ramsey 8000# PTO Winch
jeeptinker78 is offline
post #6 of 10 Old 07-13-2010, 03:31 AM Thread Starter
dodgetk81
Thanks
post #7 of 10 Old 07-13-2010, 03:32 AM
sup_mario
Newbie
I believe they will fit man. Worth trying.
sup_mario is offline
post #8 of 10 Old 07-13-2010, 06:23 AM
silverjeep
You may look into installing a V8 Durango steering box incase you go with larger tires. Seems pretty strait forward. Food for thought.
Jeep parts and accessories
silverjeep is offline
post #9 of 10 Old 07-13-2010, 12:30 PM
Jonny Jeep
Jonny Jeep's Avatar
The XJ box fits but the gearing is different. It's four turns lock to lock rather than the TJ's three. I hate it when I have to switch lock during driving. If I'd known the difference beforehand I'd have stumped up the 50 extra that one off a TJ would have cost.
Jonny Jeep is offline
post #10 of 10 Old 08-01-2010, 12:56 PM Thread Starter
dodgetk81
XJ box is on. Went on with no issues. It will be a few weeks before it gets driven
tj , xj , cherokee , wrangler , steering box , fit
Slight hitch in steering after power steering gear replacement. chip80 TJ Wrangler Technical Forum 2 10-04-2009 12:49 PM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-09-2009 11:20 PM
97 wrangler with manual steering, need donor info for power steering. anarchyfor2 TJ Wrangler Technical Forum 7 01-12-2009 07:12 AM
Steering suddenly shudders @ low speed...power steering pump? Please help pinpoint! captndiltz TJ Wrangler Technical Forum 2 08-20-2008 03:23 PM
lubricating steering linkage, steering and suspension ball joints? losfreddy TJ Wrangler Technical Forum 4 03-14-2006 04:39 PM
