will welding an installed axle fry the grease? - JeepForum.com
post #1 of 11 Old 07-19-2010, 10:54 PM Thread Starter
vicktor
I shredded the the front driver's side LCA bracket last week and ordered the heavy duty replacements from Rusty's. Just wondering if those can be welded on without taking the front end apart. Do I need to make provisions to keep the axle cool while they're getting welded?
Thanks.
__________________________________________________ _____
'02 TJ
2.5" Rancho RockCrawler, 33x10.5 BFG AT on 15x8 Xtreme Alloys
vicktor is offline
post #2 of 11 Old 07-19-2010, 10:57 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Weld it, there's no grease or oil in that area. Just use the right welder with enough amps so you get adequate penetration.
Gone on vacation until August 25.
Jerry Bransford is offline
post #3 of 11 Old 07-19-2010, 11:37 PM
MO2500
Other thing to remember that may be obvious but I'll say it anyway, keep your ground clamp close to your work. You don't want electricity arching across bearings and such
If your worried about the fluid just change it out. Inexpensive maintenance that should be done anyway. It's good to get in the habit of checking those fluids after wheeling trips to make sure they are not becoming contaminated, leading to more problems down the road.
Instagram: @omsmike
MO2500 is offline
post #4 of 11 Old 07-20-2010, 09:35 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
just make sure to pull the control arm off so you don't burn the bushings
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 11 Old 07-20-2010, 09:44 AM
300grand
And disconnect the battery before welding on the vehicle!
Tom
1995 ZJ, 4.0L, auto, 231, 3.73
300grand is offline
post #6 of 11 Old 07-20-2010, 09:52 AM
Jerry Bransford
Administrator
That's an old wive's tale, there is no need to do that. There is no electrical reason why disconnecting the battery helps or protects anything while welding.
post #7 of 11 Old 07-20-2010, 10:52 AM
MO2500
As long as the ground clamp is kept close to the work Jerry's right Electricity will take the path of least resistance and should not effect electrical systems if they are not between your ground and what your welding on.
Instagram: @omsmike
MO2500 is offline
post #8 of 11 Old 07-20-2010, 11:17 AM
Jerry Bransford
Administrator
True but even if the welder's ground connection were at the opposite end of the vehicle, which would be a very bad idea, disconnecting the battery would not provide any benefit there either. I disconnect my battery for various reasons but never just because I am welding something on my Jeep.
post #9 of 11 Old 07-23-2010, 12:13 AM Thread Starter
vicktor
Thanks guys, I wish I had welding gear (and skills, but that's why you buy new gear, right?)
Taking it to a friend of a friend at a local frame and axle shop on monday, hopefully all goes well
'02 TJ
vicktor is offline
post #10 of 11 Old 07-23-2010, 05:44 AM
Ghaniba
When I welded on new brackets on my axle, I grounded to my ECU! *ducks*
Dave aka Ghan
'99 XJ ['98 TJ, '98 ZJ 5.9 Limited - Retired]
Member, Eastern4Wheelers.org
Ghaniba is offline
post #11 of 11 Old 07-23-2010, 08:40 AM
newracer
I just finished welding in a full cage. Did not disconnect the battery.
newracer is offline
weld , welding , axle , advice , grease
Axle grease? BRAY6 TJ Wrangler Technical Forum 4 01-10-2009 04:53 PM
Grease from axle seal in dif- how to clean out Cal's TJ TJ Wrangler Technical Forum 33 12-21-2008 07:16 PM
black grease leaking from axle camac26781 YJ Wrangler Technical Forum 7 12-13-2008 06:15 PM
Quick Axle Grease Question Jeebs YJ Wrangler Technical Forum 5 12-04-2007 05:22 PM
HELP! Differential Cap or Axle Grease Cap??? Judge_B TJ Wrangler Technical Forum 3 02-25-2003 08:24 AM
