Will the toyo mud country 13.5 fit?? - JeepForum.com
post #1 of 6 Old 08-06-2009, 11:07 AM Thread Starter
leukus
I was looking at a set of toyo mud terrains to replace my MTR's - I just don't like the new tread pattern on the Kevlar version. But anyway the toyo's only come in a 35x13.50x15. The question is can I mount them on my 15x10 soft 8's and not have any rubbing or clearenxe issues?? Mt TJ has 4" X series RC lift and a 1.25" body lift. Back-spacing on the wheels is 4".
Thanks.
leukus is offline
post #2 of 6 Old 08-06-2009, 11:10 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
That will work.You might have to adjust your steering stops to keep them from rubbing the lower control arms when fully turned.
TheBoogieman is offline
post #3 of 6 Old 08-06-2009, 12:09 PM
VTJeePTJ
You should have no issues so long as your bumpstops are adjusted properly.
2003 Jeep TJ- 4" Nth LA, 4.88/ARBs, Rubicrawler, 33's, Savvy Steering, Poison Spyder Armor, etc.
VTJeePTJ is offline
post #4 of 6 Old 08-06-2009, 04:11 PM Thread Starter
leukus
Ok so help out a noob. How do you adjust your bumpstops?
leukus is offline
post #5 of 6 Old 08-06-2009, 07:46 PM
05JGC
buy extensions, new bumpstops or use hockey pucks permanently mounted on the bottom pad you see inside the bottom of the spring.
05JGC is offline
post #6 of 6 Old 08-09-2009, 01:05 PM
warren977
I'm running them on 15x10's with no problems but i think my backspacing is 3.75
warren977 is offline
Feedback on Toyo Open Country M/Ts? FatBuoy JK Wrangler Technical Forum 11 01-05-2010 07:56 PM
TOYO Tires, anyone have them.... rlj JK Wrangler Technical Forum 22 04-11-2009 11:48 AM
TOYO open country Trinitron12 YJ Wrangler Technical Forum 2 11-21-2007 11:46 PM
Will Toyo Open Country MT 33x12.50R18s fit on my stock Sahara? squid2004 JK Wrangler Technical Forum 4 09-14-2007 03:01 PM
TOYO Open country M/T frostylemon YJ Wrangler Technical Forum 3 05-11-2006 11:55 PM
