will a TJ back seat fit LJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > will a TJ back seat fit LJ?
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting Sleeves
Unread 03-05-2010, 01:23 PM   #1
azcrew
I found out the expensive way that a 2001 TJ seat will not latch open in my 2006 Unlimited. The seat belt bolts on the fender well interfere. It fits, and looks right in the open position, but it's not latched. That doesn't seem safe to me.
Can I use this seat with different brackets? Do I need to buy a 03 or later TJ seat? Will I need to buy an Unlimited back seat and brackets??
Please advise before I waste more time and money- thanks!
azcrew is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 01:48 PM   #2
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
2003-2006 TJ or LJ back seat will fit an unlimited. a 97-02 will not. the brackets are completely different.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 02:03 PM   #3
azcrew
so can I use this seat if I buy Unlimited brackets?
I appreciate the help on this.
Unread 03-05-2010, 02:16 PM   #4
never monday
no you would need early brackets. The seats were redesigned in 03
Get Savvy
never monday is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 02:22 PM   #5
DezertTJ
Phrasing
DezertTJ's Avatar
i just sold my 03 back seat... o well. sell yours and buy a 03-06 one. if it has rips or stains then buy a cover for it
06 LJ Rubicon: AZ Backcountry LJ Build
AZ TJ FOR SALE
DezertTJ is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 02:40 PM   #6
jgorm
I like the newer seat better with the auto flip up thing. The older seat is easier to get in and out of the jeep. here is what the mounts look like on a 02.
jgorm is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 02:56 PM   #7
azcrew
yes, I put those fwd brackets in my 06. The curved rear brackets didn't fit though, allowing the seat to pivot up and forward.
Anyone have a similar pic of 03 or later? Unlimited would be ideal just to be sure I get the right brackets.
Thanks again, all!
Unread 03-05-2010, 03:15 PM   #8
never monday
IIRC, the lock mechanism for 03+ is in the center of the floor, not on the wheel wells
Get Savvy
Unread 03-05-2010, 04:07 PM   #9
BlueFlame
The newer style seat has 4 brackets on the floor, 2 on each side along the sides against the fenderwells.
Nothing on the fenderwells.
The thing in the middle of the floor is where the seat belts attach.
I find the newer style is far easier to use, and easier to get in and out too.
BlueFlame is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 05:14 PM   #10
Unlimited04
no. 03-06 seats will fit 03-06 Jeeps. 97-02 seats will fit 97-02. again, the BRACKETS ARE DIFFERENT.
buy a seat for the correct year vehicle.
Unread 03-06-2010, 04:19 AM   #11
BlueFlame
or get the correct brackets for the seat and bolt them in. (LJ and TJ are same brackets, same seat.) Just need to drill a few holes.
Unread 03-13-2015, 07:43 PM   #12
Landrobert
TJ seat on an LJ
Will this Setup with these brackets work to put 2001 TJ Seat on a 2006 LJ?
http://www.tuffyproducts.com/p-109-t...rawer-130.aspx
Regards
Roberto
Landrobert is offline   Reply With Quote Quick reply to this message
Unread 03-14-2015, 04:52 AM   #13
Neil F.
Those are meant to install with the drawer. I could not tell you if you could install without the drawer but they also raise the seat up a couple of inches which you would not want. http://www.ebay.com/sch/i.html?_odkw...Text=&_sacat=0 You also have to drill holes to install them in a 03-06
Neil F. is offline   Reply With Quote Quick reply to this message
