Will these mirrors fit my door hinges? - JeepForum.com
post #1 of 8 Old 08-09-2010, 08:48 AM Thread Starter
2001TJstudent
Will these fit on the hinges when I take the door off?
Amazon.com: EA/MIRROR HARLEY-DAV - EMGO -: Automotive
2001TJstudent is offline
post #2 of 8 Old 08-09-2010, 09:24 AM
danielbuck
1946 CJ2
it doesn't seem to say how thick or how long the piece at the end is. The door hinge fits a 3/8ths bolt, and you'll need about 2 inches of bolt to stick through the hinge in order to still have thread room on the bottom to get a nut on there.
From looking at that image, I would take a guess that no it might not fit, since the bolt at the bottom is might be a little to short. Hard to tell for sure though.
I'd go to an auto parts store, or a motorcycle accessories store (Harley store?) and check out the mirrors they have there. You'll be able to look at them and see how long the bolt is.
danielbuck is offline
post #3 of 8 Old 08-09-2010, 03:17 PM Thread Starter
2001TJstudent
Ok. I went to Advanced Auto Parts and they don't have Jack Squat! I guess I can try Pep Boys, that's basically the only other one around here. There's Autozone too, guess I'll try that. None seem to have motorcycle parts though. I just thought that every Harley mirror would fit
post #4 of 8 Old 08-09-2010, 03:26 PM
danielbuck
1946 CJ2
I don't know if harley mirrors fit or not, sorry! Maybe someone else knows? if they do, that would be cool, would open up alot of mirror possibilities
post #5 of 8 Old 08-09-2010, 03:40 PM
Richisinyoface
Richisinyoface's Avatar
Can always buy a 3/8x 21/2" bolt and barrel nut. Feed the bolt up through the hinge and screw the barrel nut on the bolt. Then screw the mirror into the other end of the barrel nut.
Just Empty Every Pocket.......yup they are empty all right.................
NRA Life member
Sienna Jeep club member #65
Richisinyoface is offline
post #6 of 8 Old 08-09-2010, 10:12 PM
03CON
Your looking for what they call a long stem Harley mirror, the FLHT, FLHR, and most all the big harleys use them, the mirror you have posted is a short stem and will not work. They are dirt cheap on Ebay or at your local harley shop as new take offs.
03CON is offline
post #7 of 8 Old 08-09-2010, 10:25 PM
fang_x
Hold on before you spend big bucks, just go to a local bike store and buy a set of the clamp on bike mirrors, i spent under 10$ and they fit and work perfectly!
Super Cycle Convex Rearview Mirror | Canadian Tire
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #8 of 8 Old 08-09-2010, 10:42 PM
Colorado Jeepin
Fang, do you have a pic of it on your Jeep? Does it stay in adjustment pretty good? I like this idea, man. Especially the price, what with lack of work and all.
Move By Jeep Alone...
Colorado Jeepin is offline
hinge , mirror , fit , tj , wrangler
mirrors that go in door hinges? MC_NickP TJ Wrangler Technical Forum 24 08-17-2012 05:54 PM
Need help with hinges/mirrors MacGyver1138 YJ Wrangler Technical Forum 15 11-03-2009 08:06 AM
Cosmetic fixes? door hinges rusty and hard top window hinges peeled............... hangwire TJ Wrangler Technical Forum 8 08-25-2009 02:39 PM
Will 03-05 mirrors fit on the 87-95 hinges? rdj59 YJ Wrangler Technical Forum 2 10-04-2008 08:15 PM
Half door mirrors vs Full door mirrors (95 YJ) maximus924 YJ Wrangler Technical Forum 4 07-10-2006 08:22 PM
