Quantcast Will the stock wagon wheels (15x7) with 31x10.50 tires fit on without wheels spacers? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Will the stock wagon wheels (15x7) with 31x10.50 tires fit on without wheels spacers?
Old 11-27-2004, 07:06 PM   #1
BIGCRAZYBELL
I just wanna be able to run 31 x 10.50 with factoryJeep rims. If you have a set for sale let me know. Thanks
BIGCRAZYBELL is offline   Reply With Quote
Old 11-27-2004, 07:44 PM   #2
M1Shooter
Mine do. No rubs, no adjustments to the stops or anything.
M1Shooter is offline   Reply With Quote
Old 11-27-2004, 09:09 PM   #3
blupupher
Tere are always some for sale in the for sale forum.
31's will fit with some possible rubbing on the lower control arms on sarp turns that can be fixed with a few washers on the steering stops.
blupupher is offline   Reply With Quote
Old 11-27-2004, 11:38 PM   #4
xyz123
Super Senior Member
I had 31/10.50s on stock gambler wheels; my tires rubbed at a full lock on the lower control arms.
I recently replaced my wheels and tires with some Rubicon Wheels and Tires; The Rubicon wheels (I think they call them Moabs) are 16" with a 245 Goodyear MT/R.
They don't rub; so I guess what I'm getting at is..think about swapping to a 16" wheel so you can run the metric ratio tire; apparently they are the same height (or very close) and just a little bit narrower.
xyz123 is offline   Reply With Quote
Old 11-28-2004, 01:10 AM   #5
Av Native
I had the 31x10.5 on my jeep on stock rims, Never rubbed before the BB or after..
04 Silver TJ
4" rough country lift
1" currie MML/BL
JC fab rockers and 1" seat lift
33"BFG MT's
Nth degree adjustable upper arm
Nth degree lower arms
Power trax front locker
Av Native is offline   Reply With Quote
Glock Forum
