Will spider gears from dana 30, fit in a dana 35? - JeepForum.com
post #1 of 6 Old 07-02-2010, 03:13 PM Thread Starter
jeeper92
We started to re-gear from 3.07 to 4.56, working on 35c first. open it up and spider gears are BAD need new ones. I have extra spider gears from Dana 30, but will the spider gears fit in 35.
(Putting them in 35 looks like it will work and fits same as actual 35 did.)
Roads? Where we're going, we don't need roads.
jeeper92 is offline
post #2 of 6 Old 07-30-2010, 07:35 PM
jose_p_adams
I am wondering the same thing.
jose_p_adams is offline
post #3 of 6 Old 07-30-2010, 07:52 PM Thread Starter
jeeper92
It is the same.
But the 35 has space for 35 c clip 30 does not so will not work
jeeper92 is offline
post #4 of 6 Old 07-30-2010, 08:02 PM
jose_p_adams
Thanks. and Crap. Guess I have to run down a set of spider gears.
post #5 of 6 Old 07-31-2010, 04:13 AM Thread Starter
jeeper92
I went to local junk yard and pulled out of a 97 grand Cherokee. was easy cause was already taken apart all i had to do was pull on spider gear and they all fell out.
But they are not cheep any where 50-80 used, and 100 new good luck
jeeper92 is offline
post #6 of 6 Old 07-31-2010, 09:21 AM
BON
They will work been running my dana 30 spiders in my dana 35 for about 3 years now without a problem if you compare them they are exactly alike and have the "groove" for the c clips
BON is offline
dana 30 , dana 35 , d30 , d35 , spider gears , fit , compatible
spider gears dana 35? timritchieblue TJ Wrangler Technical Forum 10 12-22-2008 09:34 PM
any dana 35 spider gears? legend6009 TJ Wrangler Technical Forum 6 04-05-2008 12:05 PM
are all dana 35 spider gears the same? broke99tj TJ Wrangler Technical Forum 5 11-26-2007 07:14 AM
dana 35 spider gears 1.56 vs 1.62 subzeroedj TJ Wrangler Technical Forum 2 08-08-2007 07:56 PM
Are Dana 35 spider gears the same? JOKER4INK YJ Wrangler Technical Forum 7 03-23-2007 06:03 AM
