Will my Bestop still fit snug if it is removed? - JeepForum.com
post #1 of 8 Old 01-11-2010, 12:47 PM Thread Starter
Yellowhammer
My TJ had a brand new Bestop (Replace-A-Top, I think) when I bought it last December. It fits snug and there is no flopping or leaking, and it's very quiet. I've found a good deal on a factory hardtop and I'm considering buying it to run during the 4-5 months of cold weather.
Will my Bestop still perform this good if it is removed and replaced each year?
Would I be better off just taking care of my Bestop and not messing with a hardtop at this time since I don't really have an ideal place to store the top that I'm not using at the time?
Thanks in advance.
Yellowhammer is offline
post #2 of 8 Old 01-11-2010, 12:54 PM
spdcat01TJ
It seems to me that the Bestop will actually be more snug if it doesn't stay stretched on your Jeep all the time. As far as storing the hard top, that is up to you. I originally wanted a hard top, but didn't really want to store it most of the year. The only time I wish I had a hardtop is when I have a long highway trip.
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
NRA Member
'01 TJ Sahara, 3" BB front, 2.25" BB rear, 1.25 JKS BL, 1" MML, Skyjacker Hydro shocks,33/12.50x15 BFG TA/KO All Terrains homemade disco's, Hi-Lift, CB, GPS
spdcat01TJ is offline
post #3 of 8 Old 01-11-2010, 01:08 PM
biffgnar
biffgnar's Avatar
I bought dual tops when I bought mine as I thought I would need the hardtop for winter. Turned out I never used it. Soft top was perfectly fine. I too did not have good storage for the hard top which made it a complete hassle. Recently sold the hard top. Not sure about the Bestop top, but the OEM soft top when off for awhile shrinks up and becomes more snug. Have to try to get it warmed up a bit so it stretches better to get it back on.
biffgnar is offline
post #4 of 8 Old 01-11-2010, 05:16 PM
kswyg001
2010 JK Wrangler
x2-- it'll be tighter. i took mine off for a week and it was tighter
kswyg001 is offline
post #5 of 8 Old 01-11-2010, 07:43 PM
Neil F.
Storing a soft top and parts is easy. It does not take up much room and pretty much is flat. It may fit under some beds. Your soft top will last a lot longer if you swtich it with a hard top for the winter
Neil F. is offline
post #6 of 8 Old 01-11-2010, 08:27 PM
LARSONEM
I just bought a new replacement sail cloth top for my Jeep. I was amazed how compact it is when all folded up. I believe there would be no problem fitting it under a bed.
Eric Larson
1997 Red Wrangler 4.0L - 5 speed - soft top w/full frame doors - 2 inch spring spacers and 1 inch body lift - 31 x 10.50 BFG on 15 x 8 Pro Comp 8069 rims
LARSONEM is offline
post #7 of 8 Old 01-11-2010, 08:40 PM
roketman
I also have the Bestop Replac-atop and it's a great replacement. I take the top off in May and don't reinstall until October. I fold it up and put bungee straps around it and stand it up in the garage. I had a hardtop but it took up too much room when I wasn't using it.
02 Yellow TJ Sport. The axles and transfer case are 2004 Rubicon with Solid diff covers. Rubicon Express 5.5 long arm with Rancho 9000 shocks. PSC hydraulic steering. Poison Spyder tube fenders rockers and crusher corners. Blue Torch Fab front stubby, winch plate, and rear bumper. ORF cage with Rockhard harness bar. Corbeau CR-1 seats with Corbeau 4 point harness. 35" Hankook MTs on Raceline Rock Monster beadlocks. Warn M800 winch.
roketman is offline
post #8 of 8 Old 01-12-2010, 11:46 AM Thread Starter
Yellowhammer
Thanks for all the help guys. I had thought about putting it under a bed.
I have decided to pass on the hardtop at this time because I couldn't get the guy to come down to my price, plus hardtop season is only a couple of months from being over.
springs are not snug in after mad4wd spring bucket? jhoff TJ Wrangler Technical Forum 4 12-02-2009 07:10 AM
Duster to fit snug on yj? provinT13 YJ Wrangler Technical Forum 21 03-23-2009 04:49 PM
JKS Quick Disco "Snug" On Passenger Side? M2LJ TJ Wrangler Technical Forum 12 03-07-2008 12:57 PM
Help getting the Battery to fit snug melcrim TJ Wrangler Technical Forum 3 02-05-2008 06:21 PM
snug soft doors rutacon05 TJ Wrangler Technical Forum 2 05-24-2007 10:56 AM
