Will this lift fit my jeep? - JeepForum.com
post #1 of 11 Old 05-11-2013, 06:05 AM Thread Starter
TJJeepJosh
Want a little bit of a lift for my jeep but I'm cheap as well.
Would this fit my jeep even though I have a 2001 6cyl and its made for 03-06 4cyl?
http://www.extremeterrain.com/rough-...j-perf654.html
If not whats the differences?
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 11 Old 05-11-2013, 06:24 AM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
They make the same lift for your Jeep.The kit for the 4 banger would have different spring rates up front because the engine weighs less.Look into the Zone lifts.They ride better than RC.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 11 Old 05-11-2013, 05:03 PM Thread Starter
TJJeepJosh
zone makes a 1.75" 3" 4" and 4.25" lifts. As far as I've heard is a 2" lift is the highest I can get and if I get a 3" or more lift I will have drive line problems that would require buying more parts to fix.
post #4 of 11 Old 05-11-2013, 05:16 PM
tyvanwie
Very true.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #5 of 11 Old 05-13-2013, 10:05 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
You're correct. Once you get above a 3"-3.5" lift kit, you'll either need to get a slip yoke eliminator (SYE) and CV style drive shaft. That will correct your drive shaft angles and prevent vibrations and u-joint failure. You can also run a small motor mount lift (MML) and body lift (BL) to tilt the transfer case to correct the angle of the drive shaft.
The Zone 4" combo kit has 3" lift coils and 1.25" BL allowing you to clear 33" tires. It also comes with the MML that will put your driveline angles in check. So, if you're really wanting to lift that high, I'd look into that kit.
Please let me know if you have any questions!
-Zach
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #6 of 11 Old 05-13-2013, 11:23 AM
TheBoogieman
Jeepaholic
Sometimes you'll get driveline vibes with only a 2" lift.All Jeeps are different.
post #7 of 11 Old 05-13-2013, 05:12 PM
Ironhead
look into bds for a 2" kit, you wont be disappointed
Ironhead is online now
post #8 of 11 Old 05-13-2013, 07:32 PM Thread Starter
TJJeepJosh
I'm liking that bds kit with the fox shocks. looks pretty good.
post #9 of 11 Old 05-13-2013, 07:35 PM
tyvanwie
I run that as well as ironhead, except he has 3" coils up front.
tyvanwie is offline
post #10 of 11 Old 05-13-2013, 11:28 PM
Ironhead
And I'd suggest the 3" coils, even without my winch weighing down the front, the front shocks are a bit large for the 2" front springs. That being said, they have great ride charectoristics on and off road.
If I did it again from the start I'd call bds and see if they'd swap the 3" fronts in, but it only cost me $100 for the 3" springs and I have no complaints
post #11 of 11 Old 05-14-2013, 02:55 AM
Kodiak17
I'm at 2.5" with zero driveline vibes.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
2001 , 4 cyl vs 6 cyl , lift kit advice
