-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Will this lift fit my jeep? (http://www.jeepforum.com/forum/f9/will-lift-fit-my-jeep-1521799/)
TJJeepJosh 05-11-2013 07:05 AM
Want a little bit of a lift for my jeep but I'm cheap as well.
Would this fit my jeep even though I have a 2001 6cyl and its made for 03-06 4cyl?
http://www.extremeterrain.com/rough-...j-perf654.html
If not whats the differences?
TheBoogieman 05-11-2013 07:24 AM
They make the same lift for your Jeep.The kit for the 4 banger would have different spring rates up front because the engine weighs less.Look into the Zone lifts.They ride better than RC.
TJJeepJosh 05-11-2013 06:03 PM
zone makes a 1.75" 3" 4" and 4.25" lifts. As far as I've heard is a 2" lift is the highest I can get and if I get a 3" or more lift I will have drive line problems that would require buying more parts to fix.
tyvanwie 05-11-2013 06:16 PM
Very true.
Sent from my iForum using JeepPhone
XTJake 05-13-2013 11:05 AM
You're correct. Once you get above a 3"-3.5" lift kit, you'll either need to get a slip yoke eliminator (SYE) and CV style drive shaft. That will correct your drive shaft angles and prevent vibrations and u-joint failure. You can also run a small motor mount lift (MML) and body lift (BL) to tilt the transfer case to correct the angle of the drive shaft.
The Zone 4" combo kit has 3" lift coils and 1.25" BL allowing you to clear 33" tires. It also comes with the MML that will put your driveline angles in check. So, if you're really wanting to lift that high, I'd look into that kit.
Please let me know if you have any questions!
-Zach
TheBoogieman 05-13-2013 12:23 PM
Sometimes you'll get driveline vibes with only a 2" lift.All Jeeps are different.
Ironhead 05-13-2013 06:12 PM
look into bds for a 2" kit, you wont be disappointed
TJJeepJosh 05-13-2013 08:32 PM
I'm liking that bds kit with the fox shocks. looks pretty good.
tyvanwie 05-13-2013 08:35 PM
I run that as well as ironhead, except he has 3" coils up front.
Ironhead 05-14-2013 12:28 AM
And I'd suggest the 3" coils, even without my winch weighing down the front, the front shocks are a bit large for the 2" front springs. That being said, they have great ride charectoristics on and off road.
If I did it again from the start I'd call bds and see if they'd swap the 3" fronts in, but it only cost me $100 for the 3" springs and I have no complaints
Kodiak17 05-14-2013 03:55 AM
I'm at 2.5" with zero driveline vibes.
The time now is 10:15 AM.
