Will this headlight fit? - JeepForum.com
post #1 of 7 Old 04-26-2010, 11:55 AM Thread Starter
kunzcl
Hey, sorry for the rookie question but I just bought my first jeep and have been doing a lot of research on the HID conversion kit and I know everyone is using the Hella H-4 or IPF housings to then put in the HID conversion kits. My question is is that I found this deal on JC-Whitney but am unsure if this will fit my nearly stock '98 TJ.
It is a 7" round headlight that replaces a "H6024 headlight." The thing that makes me wonder is if a h-4 size bulb will fit. Here is the link and thanks in advance for helping a rookie.
Vision Plus High-performance Halogen Seal Beam Headlights - JCWhitney
EDIT: The Hella lights in question are part # 13796G
kunzcl is offline
post #2 of 7 Old 04-26-2010, 01:50 PM
Bmel17
they fit. I run IPF 7" lenses and h4 bulbs
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
post #3 of 7 Old 04-26-2010, 01:53 PM Thread Starter
kunzcl
Awesome. Thanks for the quick response.
kunzcl is offline
post #4 of 7 Old 04-26-2010, 01:55 PM
Hussler
1992 XJ Cherokee
You should run a projector with your HIDs so you do not blind oncoming drivers. Not sure if they make those for TJs but they certainly dont for XJs.
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #5 of 7 Old 04-26-2010, 02:02 PM Thread Starter
kunzcl
Yeah i was thinking about that.. but from what I hear as long as you take the time to adjust the aiming you should be good. I will def get projectors later on down the road. I read you can retrofit them from other models. Thanks.
kunzcl is offline
post #6 of 7 Old 04-26-2010, 02:47 PM
BlueFlame
BlueFlame's Avatar
If I may suggest, don't spend that kind of money on a sealed beam. (Those Hellas in that link)
Get H4 housings and bulbs, that way you save money from now on when one burns out, and you can try different bulbs if you wish.
BlueFlame is offline
post #7 of 7 Old 04-26-2010, 03:31 PM Thread Starter
kunzcl
Yeah, just now realized that.. I read this right before I purchased. Good heads up.
kunzcl is offline
headlight , hella , hid , lights
Headlight Help!!! Wildcat83 TJ Wrangler Technical Forum 2 03-27-2010 12:49 PM
help with headlight bdhawk TJ Wrangler Technical Forum 2 11-10-2009 01:34 PM
Headlight kit libertynewyork TJ Wrangler Technical Forum 32 10-20-2007 09:09 PM
Need Serious Headlight Help!! MuddyWrangla YJ Wrangler Technical Forum 4 01-16-2005 12:25 AM
Headlight Help jfarrell YJ Wrangler Technical Forum 3 04-06-2002 11:37 AM
