Will a front ZJ Dana 30 fit in a TJ? - Page 2 - JeepForum.com
post #16 of 28 Old 07-17-2010, 07:34 AM
MJMPC
Why dont you just fix what you have?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #17 of 28 Old 07-17-2010, 12:53 PM
DoGood
cause axel swaps are so cool, fixing a leaking seal is not impressive.
edit: I re-read and his axel is bent.... so a new one is probably in order. Like everyone else said, find one from a xj/zj/tj with the same gear ratio and swap it in.
^I wouldn't listen to what I say. I don't know what I'm talking about. Please use the search feature.
DoGood is offline
post #18 of 28 Old 07-17-2010, 09:21 PM Thread Starter
Brookg
i am keeping my same gear ratio... so it will not matter if the gears match since there will not be any in the new axle correct???
a dana 30 is a dana 30
Brookg is offline
post #19 of 28 Old 07-18-2010, 09:15 AM
emev0l
I would buy a complete axle ready to bolt in.
Find out what gear ratio you have and I'll find you an axle.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #20 of 28 Old 07-18-2010, 09:53 PM Thread Starter
Brookg
i finally figured out what the gear ratio is. its a front axle Dana 30 with 3.07 gear ratio. if you have any ideas where i could get one let me know ASAP!! thanks again for the help!!
Brookg is offline
post #21 of 28 Old 05-03-2015, 12:06 AM
Movinginstereo
All interesting posts. I have a 2000 Wrangler with what I have been told has 3:07 gears since it is a 5 speed that has a bent front axle tube. So I'm guessing I will need to change out the ring / pinion & axles if I swap. But do we know what year Grand Cherokee D30 is supposed to be a correct housing for the 2000 Wrangler?
Movinginstereo is offline
post #22 of 28 Old 05-03-2015, 05:15 AM
emev0l
92-98
emev0l is offline
post #23 of 28 Old 01-25-2016, 06:06 PM
Tjexy
What about a wj front d44 will that bolt right into an 06 tj?
Tjexy is offline
post #24 of 28 Old 01-26-2016, 06:56 AM
biffgnar
biffgnar's Avatar
WJ's had front D44s?
Romney in 2020!
biffgnar is online now
post #25 of 28 Old 01-27-2016, 10:05 AM
Tjexy
I'm pretty sure my 99 wj has a d44 front and rear it's a limited with the v8 in it but I was wondering if the front axle would bolt up to my tj
Tjexy is offline
post #26 of 28 Old 01-27-2016, 10:08 AM
biffgnar
biffgnar's Avatar
Whatever it is I don't think it is bolt up. TJ and XJ fronts (and maybe ZJ depending on who you ask) are bolt up.
Romney in 2020!
post #27 of 28 Old 01-27-2016, 10:13 AM
MurdaJs
No wj came with a 44 front. D30 front and 44a rear unless something was swapped aftermarket. No matter what you have, it won't just bolt up to a tj
While the zj d30 will bolt in, they only came with 3.55 and 3.73 gearing
MurdaJs is offline
post #28 of 28 Old 01-27-2016, 01:55 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A front Dana 30 looks enough like a Dana 44 that it fools a lot of people. Your WJ came from the factory with a Dana 30 up front.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
axle , axle swap , tj , zj
Question about Dana 30 to G2 Dana 44 front swap snowcrash TJ Wrangler Technical Forum 31 04-08-2013 07:29 PM
aftermarket front dana 44 vs. built dana 30 bigwyrm TJ Wrangler Technical Forum 9 04-04-2011 12:02 PM
upgrading from a dana 30 to a dana 44 front axle cprats TJ Wrangler Technical Forum 12 12-10-2007 08:20 AM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 08:20 PM
4:10, 33's, Dana M35 Rear, Dana 30 Front Jeeper-4-Life TJ Wrangler Technical Forum 1 02-10-2004 03:48 PM
