Will a front ZJ Dana 30 fit in a TJ? - JeepForum.com
post #1 of 28 Old 07-15-2010, 10:28 PM Thread Starter
Brookg
I have a 97 TJ and it started leaking gear oil. I brought it in and they said i have a bent front axle housing!!! I have been looking around and tj axles are to much for my wallet!!! Will a front axle from a ZJ Cherokee fit in my TJ?. It is a Dana 30. Or is there another alterative way to fix my problem? Possibly bend it back and put a truss on it? Any tips would be great!!
Brookg is offline
post #2 of 28 Old 07-15-2010, 11:13 PM
MJMPC
Where is it leaking from? A pic would help.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 28 Old 07-16-2010, 12:45 AM
RogueSpear2023
I am pretty sure a ZJ front axle will not work the brackets are in the wrong spots, but an XJ Cherokee has a front high pinion D30 in the 99s and older that is a direct bolt in to a TJ, and is and upgrade over the low pinion D30 you have now. The 2000-01 XJs had LP D30s that are also a bolt in, but not an upgrade.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #4 of 28 Old 07-16-2010, 08:22 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
A ZJ front is identical to a TJ front with the exception of CV joints in the axles.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 28 Old 07-16-2010, 03:07 PM Thread Starter
Brookg
[IMG]n303400229_19334_2739[/IMG]
i do not know if the image will show?
it is coming out of the axle housing near the passenger knuckle.
Soooo one of you says no and the other says yes???? as for the cv joints, i will use them from my tj and not change them over. will i be ok there?
Brookg is offline
post #6 of 28 Old 07-16-2010, 03:28 PM
freeskier93
Look for something with high pinion. Also don't worry about brackets, they can easily be replaced. It will probably cost you more to search for a direct bolt in d30 when you can just find any HP D30 and get new brackets.
Or for about 8-900 dollars you can buy a brand new HP D30 from East Cost Gear Supply and have it custom built. They also sell just the housings for 150, don't think the carriers and gears are interchangeable, but if everything else on your old axle is still good it can be reused.
freeskier93 is offline
post #7 of 28 Old 07-16-2010, 03:29 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The guy that's saying yes is doing so because he helped swap a set of TJ axles under a ZJ. The front is a straight bolt in and the rear has to be modified to work.
I am Savvy
mrblaine is offline
post #8 of 28 Old 07-16-2010, 10:53 PM Thread Starter
Brookg
@ freeskier... thanks for linking me to east coast gear supply!! that will work great!! all i need is the housing. all i have to do is take all my stuff out and throw it in. and with out spending to much$$$. thanks again everyone!! any more input will be great!
Brookg is offline
post #9 of 28 Old 07-16-2010, 10:56 PM
emev0l
Make sure it's the correct gear ratio!
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #10 of 28 Old 07-16-2010, 11:02 PM
BriansCJ
1994 XJ Cherokee
Yes a ZJ front axle will bolt in. The only downside is the weaker stock CV axle joints but you can swap in your u-joint axle shafts and keep the CVs for spares.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #11 of 28 Old 07-16-2010, 11:06 PM
freeskier93
Confirm that gears and carrier from a d30 can be swapped into a HP D30.
post #12 of 28 Old 07-16-2010, 11:17 PM Thread Starter
Brookg
ok thanks ill keep it in mind!!!
Brookg is offline
post #13 of 28 Old 07-16-2010, 11:34 PM
emev0l
You can not use low pinion gears in a high pinion axle.
emev0l is offline
post #14 of 28 Old 07-16-2010, 11:39 PM
emev0l
97 4.0 manual TJ's came standard with 3.07 gears
but...
97 was the only year that 4.0 manuals had an optional 3.55 gear ratio.
Try and check your diff covers for a tag that has your gear ratio.
emev0l is offline
post #15 of 28 Old 07-17-2010, 06:50 AM
cj847
The front D30 from an XJ, MJ, TJ, ZJ are all interchangable. I had a 97 ZJ axle in my TJ for a couple of years, now it has a 89 XJ axle in it. Some ZJ had CV but I think the majority are u joint axles. I bolted my 97 ZJ axle in from caliper to caliper, and it was 100% identical to the 97 TJ axle.
Old XJ axles had smaller u joints than TJ but you can pull the axles from your TJ and slip them right in. The thing you have to watch out for is there were 3 combinations of hub/rotors during the run. Loosely speaking there were pre 1990 hub/rotor; the 90,s rotor/hub; and 2000 and up rotor/hub. Each model seems to have changed in a different year so you would have to seach to find the exact date.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
axle , axle swap , tj , zj
Question about Dana 30 to G2 Dana 44 front swap snowcrash TJ Wrangler Technical Forum 31 04-08-2013 07:29 PM
aftermarket front dana 44 vs. built dana 30 bigwyrm TJ Wrangler Technical Forum 9 04-04-2011 12:02 PM
upgrading from a dana 30 to a dana 44 front axle cprats TJ Wrangler Technical Forum 12 12-10-2007 08:20 AM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 08:20 PM
4:10, 33's, Dana M35 Rear, Dana 30 Front Jeeper-4-Life TJ Wrangler Technical Forum 1 02-10-2004 03:48 PM
