Will coils from 05 Rubi Unlimited fit 05 TJ Sport? - JeepForum.com
post #1 of 12 Old 10-10-2012, 08:58 AM Thread Starter
Peyts
I just got my hands on a set of springs from a 2005 Rubicon Unlimited.
I'm looking at doing a 2" BB lift & putting 31x10.50 tires on my currently stock 2005 TJ Sport (4 ltr, 6 cyl, 6-speed manual trans).
Here's my questions:
*Will those Rubi Unlimited coils even fit properly on my TJ Sport?
*Would I gain any advantage by putting on those Rubi springs?
*Would there be any lift in my TJ with those springs on?
*Should I do the 2" BB with the Rubi coils or with my stock springs?
Thanks a million for your time!
Peyts is offline
post #2 of 12 Old 10-10-2012, 09:04 AM
DBLJ
DBLJ's Avatar
Yes
Not really
If any, very minor.
Use the Rubi springs.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is online now
post #3 of 12 Old 10-10-2012, 09:06 AM
Jason
There won't be any height difference in the coils between Rubi and Sport, and they should be interchangeable. I don't believe there wouldn't be any advantage in using the Rubi springs unless something is wrong with your current ones.
Jason is offline
post #4 of 12 Old 10-10-2012, 09:07 AM
Ironhead
which ever ones have less miles on them
Ironhead is offline
post #5 of 12 Old 10-10-2012, 09:08 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Rubi springs are stiffer.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #6 of 12 Old 10-10-2012, 10:04 AM
biffgnar
biffgnar's Avatar
Are you sure? I was under the impression that there were some Sport configurations (e.g. dual tops) that got the same springs as the Rubicons.
biffgnar is offline
post #7 of 12 Old 10-10-2012, 10:31 AM
TheBoogieman
I think the hard top Jeeps have the same stiffer rate as the Rubi.
post #8 of 12 Old 10-10-2012, 10:49 AM
goofus
Look at the labels on the springs, if present. 106AA and 130AA are the stiffest. I only found those on my 2003 Rubicon. My 05 LJ came with 105AB and 129AB springs. The lower those part numbers are, the softer the spring. Dimensions are all identical, nonetheless.
2013 2500HD
2005 Unlimited
2003 Rubicon
2000 SE
1997 XJ
85 FJ-60
goofus is offline
post #9 of 12 Old 10-10-2012, 11:03 AM
Jason
My hardtop-equipped sport had 104 rears and 128 fronts.
Jason is offline
post #10 of 12 Old 10-10-2012, 12:13 PM Thread Starter
Peyts
Thanks for all the input! I reckon that, based on above, the springs will fit my TJ Sport.
The question now, then, is whether or not I should replace my stock springs with the Rubi Unlimited ones when I do the 2" BB lift.
I'll take a look to see if I can find any number codes on the coils, as mentioned by goofus. That being said, should the stiffer of the two springs be the ones that go on my Jeep? Or the ones with the less miles, as suggested by Ironhead Jed? Or just put the Rubi ones on because they are better?
Peyts is offline
post #11 of 12 Old 10-10-2012, 12:16 PM
TheRealKTrain
JK Wrangler
The question now, then, is whether or not I should replace my stock spings with the Rubi Unlimited ones when I do the 2" BB lift.
I'll hold your hand if you want...
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #12 of 12 Old 10-11-2012, 05:19 AM Thread Starter
Peyts
Though I appreciate your gesture of romance, I'll have to pass.
Peyts is offline
coils , lift , springs , stock , suspension
