Which will be a better ride-2.5" lift and 1" body lift or 3.5"/4" lift?
#1 | |
So, in my continuing quest that involves my Jeep running 33"s, and both looking good to the eye and feeling good to the a**, I'm trying to decide what lift will offer better on-road handling. All other things-namely, manufacturer-equal (I'm probably going Rubicon Express for the springs and assorted other parts, and OME or Skyjacker for the shocks), which will provide a better on-road ride-a 2.5" suspension lift with a 1" body lift, or a 3.5" or 4" suspension lift?
Comfort is a big thing for me, mainly because next June, I'm going to have to hook a U-Haul trailer up to it, load myself, 2 friends and 4 (Yes, 4) cats in the Jeep and drive it the 5000 KM back home to Whitehorse when I graduate. So, I'd like to get it riding in a manner such that I'll be able to feel my butt when I get back. ![]()
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography." -TTAC |
#2 |
do a "4.5 rubicon express kit, switch the springs for "3.5, and call it a day
www.youtube.com/kgries http://photobucket.com/kgries in the 80's.... we had Ronald Reagan, Bob Hope, and Johnny Cash. Now we have Obama, No Hope, and No Cash.. |
#3 |
want it rite or rite now?
OME 2.5" springs, shocks, 1.25" body lift and mml
on short arms the higher ya go the rougher the ride along with less stability.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#4 |
Generally speaking regarding spring height on a short arm lift, the shorter the springs- the more parallel to the ground the control arms will be, thus giving a more compliant ride. So all thing being equal quality-wise, a shorter spring lift with a BL will theoretically give a more compliant ride than a longer spring lift. But that being said, often times the difference of an inch is tough to feel in the seat of the pants, especially on SA lifts under 4". Anything over 4" on a SA and the ride becomes noticably stiffer as that is when the CA's really are pitched down acting more like struts and relaying road variables to the chassis instead of absorbing them through the springs/shocks.
Give BDS a look for springs and/or shocks. I'm running their 3" springs and shocks and the on-road ride is just as nice as the OME 2.5 kit they replaced. Both kits gave a very close to stock ride quality. The BDS kits are quite reasonable price-wise and have a lifetime guarrantee on everything but the shocks. |
#5 | |
However 2.5" suspension on SA with OME's and a 1" BL would ride very good. If you are thinking of LA try to keep your LCG low especially if you want to tow something. ![]()
2000 XJ 4" 33's... TJ on 1 tons and 40's after Afghanistan! |
#6 |
Doing the BL is also lifting less of the weight into the air.
Instead of just a spring lift lifting the body along with everything else. So that keeps you a bit more stable, even though you still got the body up high. ~John
www.jtice.com 05 Jeep Rubicon 2.5" OME Lift, JKS BL/MML, JKS Trackbars, Rokmen TT Skid, Skid Row Engine Skid, ARB Bull Bumper, Warn M8000, Poison Spyder Rock Rails, Omix Front Diff Skid, Nth Degree Rear Diff Slider, Garvin Roof Rack, High Rock Rear Bumper |
#7 |
not to mention the sye, cv shaft or dropping the t-case ya likely wont need to do.
#8 |
#9 | |
So, yeah, I'm thinking I'll go for a 2.5" lift and 1" BL. It won't be any less rough then the comparable SL, but it'll cost so much less. Off-road performance probably won't be as much, but for the moment, my Jeep spends most of the time on pavement anyways.
#10 |
keepin it on the hwy ya can also skip out on replacing the lower control arms,
keep off them rocks!.... ![]()
#11 | |
'02 TJ X Apex Edition '00 XJ Sport |
#12 |
Umm ya...
If those weren't stock CA i am pretty sure that they would be just as abused. If they were LA they would probably be wrecked. There is nothing wrong with stock CA for just a 2.5" lift.
#13 |
Annother benefit to a 1" BL / 2.5" lift is that because of the BL you can also trim your gas skid (or buy aftermarket) for more ground clearance. Plus many belly-up skids require a 1" BL for clearance issues if you decide to go that route (though, at any height other than stock, a belly-up skid conversion will require the SYE, CV driveshaft mods).
I've been running a 2" lift, 1" BL/MML and have greatly enjoyed this combiniation for offroading. On road things are pretty stable.
- Jay |
#14 | |
mud, snow, dirt, trail riding... ya don't need new lower arms, thats what i was trying to show.. lol
#15 |
this is the stuff I play on alot and is what took out those stock arms..
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
