Will 4.56 Overheat a D44/D30?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Will 4.56 Overheat a D44/D30??
Poison Spyder Dana 44 Bombshells Are BACK!!Poison Spyder RockBrawler II Rear Bumper with Tire CarrierPoison Spyder from CCOR!
Unread 01-29-2009, 12:45 PM   #1
Mudsailer
I just talked to a shop about regearing my D44 & D30 to 4.56 (based on what I read on this forum) but they told me that gear ratio tends to overheat and blow fluid out the breather. He recomended 4.10.
I have a 5 speed, 4.0 with 33's. Not sure if it would be worth the cost to just upgrade from 3.73 to 4.10.
Anyone have this problem or should I find another shop?
Mudsailer is offline   Reply With Quote
Unread 01-29-2009, 12:46 PM   #2
2005X
find another shop. look at my specs and then ask the question again
www.youtube.com/kgries
2005X is offline   Reply With Quote
Unread 01-29-2009, 12:47 PM   #3
spokanistan
^yeah that^
Superman never made any money for saving the world from Solomon Grundy.
spokanistan is offline   Reply With Quote
Unread 01-29-2009, 12:50 PM   #4
Imped
Balls
Imped's Avatar
They don't have a clue what they're talking about. Go to a different shop.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 01-29-2009, 12:50 PM   #5
2005X
with this being said, anytime you get new gears there is a break in period, after i put mine in i drove for 30 miles then stopped to let the diff cool down, did that 3 times then bever looked back. some people say there is no break in period, i just did what my shop said. but to say you cant run 4:56 ever because of heat is retarded
Unread 01-29-2009, 01:40 PM   #6
TimBrown
I've been running 4.56's in my D30/D44 with 31 tires and haven't any problem. I believe your shop is mistaken.
TimBrown is offline   Reply With Quote
Unread 01-29-2009, 01:41 PM   #7
robncar
I had to put out my 4.88's just the other day, big fire...
What can happen is a couple of things:
1. Use of an aftermarket cover with a higher fill plug. Owner fills to the bottom of the hole (now over filled) just like they did with the stock cover and gear lube sprays out of the breather.
2. Installer does not cut adequate drain back holes during an ARB install (it's in the install directions!) and gear lube sprays out of the breather. Ask me how I know this one...
[CENTER][SIZE="5"][COLOR="DarkRed"][B]DON'T FEAR THE RE-GEAR!!![/B][/COLOR][/SIZE]
[CENTER][B][COLOR="DarkRed"][SIZE="3"]______[/SIZE]
[SIZE="3"]|_____|[/SIZE]
[SIZE="2"](O|||||||O)[/SIZE]
[SIZE="1"]|______|[/SIZE][/B][/COLOR]
[SIZE="5"][][/SIZE]===[SIZE="5"]o[/SIZE]==[SIZE="5"][][/SIZE][/CENTER]
[SIZE="4"][COLOR="DarkRed"][B]RED JEEP CLUB MEMBER #430[/B][/COLOR][/SIZE][/CENTER]
robncar is offline   Reply With Quote
Unread 01-29-2009, 03:59 PM   #8
Greg_Volkman
he is right that the gears will get hotter, and there may be times when the oil expands, but it's not going to make a difference to the gears...it's not going to burn them up.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Unread 01-31-2009, 06:01 AM   #9
GreenJip
Maybe they're just trying to unload a set of 4:10 gears on who he presumes to be naive. Not saying you are. Find another reputable shop that will perform the services you ask for. Not saying they're not.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/
GreenJip is offline   Reply With Quote
Unread 01-31-2009, 06:23 AM   #10
BarneyJEEP
they get too hot and burn up IF they set them up wrong...
http://www.kifourwheelers.com/
BarneyJEEP is offline   Reply With Quote
