Will 3.08 internals work with a 3.07? - JeepForum.com
post #1 of 4 Old 07-26-2012, 04:15 PM Thread Starter
Lace
Screwed up my internals in my rear and picked up an older d35 with 3.08 from an xj.
Basically wondering if I can transfer the internals (carrier, ring gear, etc) from the xj d35 3.08 into my d35 3.07. And how hard is this to do correctly?
My Jeep has been sitting for a month now and I'm tried of not being able to go anywhere while the wife is working.
- Local jeep forum!
2003 Wrangler X 4.0L | 2006 Liberty Limited
2006 Grand Cherokee Limited 4.7L - Traded |2005 Liberty Limited - RIP
Lace is offline
post #2 of 4 Old 07-26-2012, 06:12 PM
JEK3
JEK3's Avatar
I would assume a d35 is a d35, so they should fit. As for the slight difference in ratios, I know some Jeeps shipped with a 4.11 front and 4.10 rear (or was it the other way around? Someone will undoubtedly correct me). As for how easy it is to swap, it's not. Basically, you're doing a regear. You can't just swap the shims over (or reuse the originals) and hope it works. You have to go through the whole process. Doable, but not for the meek.
JEK3 is online now
post #3 of 4 Old 07-26-2012, 08:29 PM
MattJeep
2003 WJ
Umm not sure, but I would just keep searching for a used D35 from a TJ with 3.07's. Seems alot easier, they're all over the place during summer. Good luck.
MattJeep is offline
post #4 of 4 Old 07-26-2012, 09:56 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
For all TJs with the exception of the Rubicon which has the same axle front and rear, there is a .01 ratio difference between the front and rear due to the difference in f/r ring gear sizes. So Jeeps come with these combinations of f/r ratios... 3.07/3.08, 3.54/3.55, 3.73/3.74, 4.10/4.11.
The .01 ratio difference is ok due to our 4x4 system being designed for loose low-traction road surfaces. Even if they were exactly the same however, you still couldn't drive in 4x4 on the street since the front axle turns faster than the rear axle does on curves and turns. Offroad, it's a non-issue.
Jerry Bransford is offline
d35 , dana , tj , wrangler
Aah! Need help with HVAC internals vanillathrilla TJ Wrangler Technical Forum 7 06-13-2011 08:25 PM
TJ d30 internals fit yj d30? rottenmontanans YJ Wrangler Technical Forum 7 02-05-2009 09:08 PM
np231 swap internals or make it work aaronc88 YJ Wrangler Technical Forum 12 12-30-2008 06:44 PM
Question about Tub Internals... SirGCal TJ Wrangler Technical Forum 21 02-06-2004 03:00 PM
