Will 2.5L engine from 98 Cherokee fit 98 Wrangler - JeepForum.com
post #1 of 4 Old 06-30-2010, 08:55 AM Thread Starter
gary1
gary1's Avatar
2.5L engine is shot in my 1998 Wrangler. I have access to a 2.5L engine in a 1998 Cherokee. They are both Manual transmission. Will this engine be a direct fit. Can my computer and wiring be used?
To acquire knowledge, one must study; but to acquire wisdom, one must observe.
gary1 is offline
post #2 of 4 Old 06-30-2010, 09:21 AM
Sundowner
I can't say for sure as I'm not familiar with the 2.5, but if you have the fan shroud, air intake, exhaust, and all the other peripherals for your Wrangler, then it shouldn't be a big issue. You're basically swapping out the long blocks, and the computer shouldn't know what engine is in there. Theoretically, it should work just fine.
Sundowner is offline
post #3 of 4 Old 06-30-2010, 10:02 AM
LJameson
Yep, as long as you're only using the block, you're fine.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #4 of 4 Old 06-30-2010, 10:11 AM Thread Starter
gary1
gary1's Avatar
OK, good. I was quite sure it would bolt right up to the bell housing, but wasn't sure about the motor mounts, etc.
gary1 is offline
harness , 2.5L , engine , swap , cherokee , wrangler , xj , tj
94 Cherokee engine donor for 91 Wrangler 91wrangleryj YJ Wrangler Technical Forum 4 03-24-2010 03:19 PM
cherokee engine wire to wrangler dashboard meedel YJ Wrangler Technical Forum 8 11-02-2009 11:29 PM
Cherokee Engine to Wrangler ? Zazoos YJ Wrangler Technical Forum 5 08-22-2007 06:09 PM
Cherokee engine in a Wrangler Sarge37 YJ Wrangler Technical Forum 2 06-11-2002 08:28 PM
89 Cherokee engine into a 93 wrangler???? Gerry YJ Wrangler Technical Forum 3 05-30-2002 08:07 AM
