Will 15x10" wheels with 3 5/8 bs stuff with 4" of lift? - JeepForum.com
post #1 of 4 Old 03-02-2005, 08:03 PM Thread Starter
ryan_289
I am looking at a set of eagle alloy wheels style 186. They are 15x10's with 3 5/8 bs. Will these stick out to far and cause rubbing problems with a 4" lift? I like the aluminum slyle wheels better than the black steel wheels but on most posts I have noticed that most people like the 4" bs. I havent found an aluminum wheel that has this bs.
01 TJ sport. 4.0, manual. SOLD
52 Willys M38. Currently in pieces in my shop. FINISHED AND SOLD.
1948 Willys CJ2A
ryan_289 is offline
post #2 of 4 Old 03-02-2005, 08:18 PM
crawldit
crawldit's Avatar
How wide are the tires that you want to run??? My 33x13.5 on a 15x10 with 3 3/4 BS rubbed if I looked at it cross-eyed. It is a very W I D E setup.
2005 Rubicon :
4.0 Automatic,4.11 gears,4:1 Transfer Case
Teraflex 3" Coils,Rancho 9000x's,35" KM2's,(fenders...what fenders?), Cobra CB, Lowrance Baja 480c GPS,2"Wheel Spacers, Big Daddy Tie Rod,Superior Evolution Shafts.
crawldit is offline
post #3 of 4 Old 03-02-2005, 08:22 PM Thread Starter
ryan_289
I am planning on running 33x12.50 tires. If I dont want any rubbing I guess I need to run 15x8's huh?
1948 Willys CJ2A
ryan_289 is offline
post #4 of 4 Old 03-02-2005, 08:27 PM
crawldit
crawldit's Avatar
With the 12.5 tires you probably would want to run an 8" rim anyway. Otherwise you have to worry about losing the bead when you air down. Maybe someone with this setup can speak up with better advice ?
2005 Rubicon :
crawldit is offline
2.25" BB + 1" BL + soft 8's 15x10 and duratrac 33x12.50x15 outlanderbz TJ Wrangler Technical Forum 23 07-01-2013 11:24 PM
Black 15x10" wheels on Hunter Green Jeep Spice Top and interior cavinman TJ Wrangler Technical Forum 8 02-12-2007 07:40 PM
31" 15x10.50's w/ a RC 4" lift, pic request 1993jeep YJ Wrangler Technical Forum 9 05-19-2006 02:43 AM
15x8 or 15x10" rims on 4" lift? ryan_289 TJ Wrangler Technical Forum 10 02-25-2005 10:46 PM
31x12.5 with 15x10 wheels & 2.5" lift wsuspinster YJ Wrangler Technical Forum 4 11-05-2002 12:00 PM
